Nirva
1 year agoQuartus 23 abort (core dump) on Linux
This started happening yesterday; I don't know why it's happening. Here's the output from the strace program: Edit: I have reinstalled my entire OS to isolate the problem. It did not solve the issue...
- 1 year ago
I installed it on Arch Linux, via the AUR. The issue has been found out and is described within the comments at the AUR page. It has to do with the fontconfig library.
RichardT_altera
1 year agoAre you trying to install Quartus Standard 23.1 in OS RHEL 7.2?
The OS RHEL 7.2 is not officially supported.
Please check the supported OS list for Quartus Standard 23.1:
Intel® Quartus® Prime Standard Edition Version 23.1 readme.txt
FYI, You may try to install on the non-supported OS but you will have to bear your own risk and there will be no technical support as well.
Additionally, how do you install Quartus?
Are you install using the 'Quartus Prime Installer' or the 'Complete Download .tar file'?
Richard Tan
