Nirva
1 year agoQuartus 23 abort (core dump) on Linux
This started happening yesterday; I don't know why it's happening. Here's the output from the strace program: Edit: I have reinstalled my entire OS to isolate the problem. It did not solve the issue...
- 1 year ago
I installed it on Arch Linux, via the AUR. The issue has been found out and is described within the comments at the AUR page. It has to do with the fontconfig library.
Ahmed-Ramsey
1 year agoCan you mention how did you solve it ?
Nirva
1 year agoThe issue was the update to fontconfig. There are a few ways to solve it. Installing fontconfig-ubuntu from the AUR, which replaces and provides fontconfig, was the way I solved it.
You can also edit your pacman.conf to ignore updates to fontconfig and roll it back to the 2-15 version
Note that keeping outdated packages like this on your system could cause many problems.
