12 years agoQsys problem in connecting Avalon-MM master and slave with different symbol widths
hi, i cannot connect avalon-mm master with a symbol width of 8 and avalon-mm slave with a symbol width of 9.
i am trying to connect a 128-bit width master with 8-bit symbol of a clock crossing bridge to a 72-bit width slave with 9-bit symbol of qdrii+ sram controller. when connecting them, qsys gives an error message "error: system.: signal m0[8] and signal avl_r[9] must have the same symbol width." i cannot change the 9-bit symbol width of the qdrii+ controller. i also have to 8-bit symbol for the bridge because it's slave is also connected to avalon-mm master of pci-express interface. could you help me?
it is okay for me to connect only 64 bits from the 72 bits of the qdrii+ controller to make a symbol width 8 bits from 9 bits.
micky
