12 years agoHi,
After all, I knew that I still had a problem of the QDRII+ controller. I connected the 64-bit read/write Avalon-MM ports of the QDRII+ controller to BAR2 of PCIe core. The PCIe core works correctly. However, the QDRII+ core operates incorrectly. At every address, the least significand 4 bits in the 64 bits are always "0000", while the remaining 60 bits match the written 60 bits. All the four QDRII+ SRAM @ 500MHz on Terasic DE5-NET board have the same problem. We configured different DE5-NET boards with the same bit stream, they also had the same problem. I carefully made settings on the QDRII+ core based on the sample design by Terasic... Can anyone help me? Many thanks, Micky
