14 years ago
Need help on a design constraint file for a IP
Hi there,
I am using Altera's Triple_Speed_Ethernet Mac IP core. And while I was compiling the IP with my design, there prompts warnings that lots of constraints in the generated sdc file from the IP were ignored due to some naming problems.
The sdc file for the IP has a customer modifiable area that for me to change the names of the clocks. I have no idea how to change the clock names to make it work. Like how do I set the SYSTEM_PATH_PREFIX?
Thanks a lot for any suggestions here.
# *************************************************************# Customer modifiable constraints, value is set default by constraints# *************************************************************# Hierarchical path to the TSE
set SYSTEM_PATH_PREFIX ""# Frequency of network-side interface clocks or reference clocks
set TSE_CLOCK_FREQUENCY "125 MHz"# Frequency of FIFO data interface clocks
set FIFO_CLOCK_FREQUENCY "100 MHz"# Frequency of control and status interface clock
set DEFAULT_SYSTEM_CLOCK_SPEED "66 MHz" # Name the clocks that will be coming into the tse core named changed from top level
set TX_CLK "tx_clk"
set RX_CLK "rx_clk"
set CLK "clk"
set FF_TX_CLK "ff_tx_clk"
set FF_RX_CLK "ff_rx_clk"
set TBI_TX_CLK "tbi_tx_clk"
set TBI_RX_CLK "tbi_rx_clk"
set REF_CLK "ref_clk"
    Check if the clock names between quotes match those feeding the relevant TSE mac pins in your Quartus design.
    --- Quote Start ---
    --- Quote End ---
    Yes I think they do match. Here is the instantiation of the TSE mac IP and attached is the complete sdc file for the TSE core.
    I have generated four ports in my IP, and the sdc file has a mechanism converting the names for all the four ports.
    Instantiation of my IP in the quartus design:
    triple_mac triple_mac_inst(
    .clk(sys_clk),
    .reset(~rst_n),
    .address(reg_address),
    .read(reg_read),
    .writedata(reg_writedata),
    .write(reg_write),
    .rx_afull_clk(),
    .rx_afull_channel(),
    .rx_afull_data(),
    .rx_afull_valid(1'b0),
    .data_tx_data_0(data_tx_data_0),
    .data_tx_eop_0(data_tx_eop_0),
    .data_tx_error_0(data_tx_error_0),
    .data_tx_sop_0(data_tx_sop_0),
    .data_tx_valid_0(data_tx_valid_0),
    .data_rx_ready_0(data_rx_ready_0),
    .tx_clk_0(tx_clk_0),
    .rx_clk_0(rx_clk_0),
    .gm_rx_d_0(gm_rx_d_0),
    .gm_rx_dv_0(gm_rx_dv_0),
    .gm_rx_err_0(gm_rx_err_0),
    .m_rx_d_0(m_rx_d_0),
    .m_rx_en_0(m_rx_en_0),
    .m_rx_err_0(m_rx_err_0),
    .m_rx_col_0(m_rx_col_0),
    .m_rx_crs_0(m_rx_crs_0),
    .set_10_0(set_10_0),
    .set_1000_0(set_1000_0),
    .tx_crc_fwd_0(tx_crc_fwd_0),
    .data_tx_data_1(data_tx_data_1),
    .data_tx_eop_1(data_tx_eop_1),
    .data_tx_error_1(data_tx_error_1),
    .data_tx_sop_1(data_tx_sop_1),
    .data_tx_valid_1(data_tx_valid_1),
    .data_rx_ready_1(data_rx_ready_1),
    .tx_clk_1(tx_clk_1),
    .rx_clk_1(rx_clk_1),
    .gm_rx_d_1(gm_rx_d_1),
    .gm_rx_dv_1(gm_rx_dv_1),
    .gm_rx_err_1(gm_rx_err_1),
    .m_rx_d_1(m_rx_d_1),
    .m_rx_en_1(m_rx_en_1),
    .m_rx_err_1(m_rx_err_1),
    .m_rx_col_1(m_rx_col_1),
    .m_rx_crs_1(m_rx_crs_1),
    .set_10_1(set_10_1),
    .set_1000_1(set_1000_1),
    .tx_crc_fwd_1(tx_crc_fwd_1),
    .data_tx_data_2(data_tx_data_2),
    .data_tx_eop_2(data_tx_eop_2),
    .data_tx_error_2(data_tx_error_2),
    .data_tx_sop_2(data_tx_sop_2),
    .data_tx_valid_2(data_tx_valid_2),
    .data_rx_ready_2(data_rx_ready_2),
    .tx_clk_2(tx_clk_2),
    .rx_clk_2(rx_clk_2),
    .gm_rx_d_2(gm_rx_d_2),
    .gm_rx_dv_2(gm_rx_dv_2),
    .gm_rx_err_2(gm_rx_err_2),
    .m_rx_d_2(m_rx_d_2),
    .m_rx_en_2(m_rx_en_2),
    .m_rx_err_2(m_rx_err_2),
    .m_rx_col_2(m_rx_col_2),
    .m_rx_crs_2(m_rx_crs_2),
    .set_10_2(set_10_2),
    .set_1000_2(set_1000_2),
    .tx_crc_fwd_2(tx_crc_fwd_2),
    .readdata(reg_readdata),
    .waitrequest(waitrequest),
    .mac_tx_clk_0(mac_tx_clk_0),
    .mac_rx_clk_0(mac_rx_clk_0),
    .data_tx_ready_0(data_tx_ready_0),
    .data_rx_data_0(data_rx_data_0),
    .data_rx_valid_0(data_rx_valid_0),
    .data_rx_eop_0(data_rx_eop_0),
    .data_rx_sop_0(data_rx_sop_0),
    .data_rx_error_0(data_rx_error_0),
    .pkt_class_data_0(pkt_class_data_0),
    .pkt_class_valid_0(pkt_class_valid_0),
    .gm_tx_d_0(gm_tx_d_0),
    .gm_tx_en_0(gm_tx_en_0),
    .gm_tx_err_0(gm_tx_err_0),
    .m_tx_d_0(m_tx_d_0),
    .m_tx_en_0(m_tx_en_0),
    .m_tx_err_0(m_tx_err_0),
    .ena_10_0(),
    .eth_mode_0(eth_mode_0),
    .mac_tx_clk_1(mac_tx_clk_1),
    .mac_rx_clk_1(mac_rx_clk_1),
    .data_tx_ready_1(data_tx_ready_1),
    .data_rx_data_1(data_rx_data_1),
    .data_rx_valid_1(data_rx_valid_1),
    .data_rx_eop_1(data_rx_eop_1),
    .data_rx_sop_1(data_rx_sop_1),
    .data_rx_error_1(data_rx_error_1),
    .pkt_class_data_1(pkt_class_data_1),
    .pkt_class_valid_1(pkt_class_valid_1),
    .gm_tx_d_1(gm_tx_d_1),
    .gm_tx_en_1(gm_tx_en_1),
    .gm_tx_err_1(gm_tx_err_1),
    .m_tx_d_1(m_tx_d_1),
    .m_tx_en_1(m_tx_en_1),
    .m_tx_err_1(m_tx_err_1),
    .ena_10_1(),
    .eth_mode_1(eth_mode_1),
    .mac_tx_clk_2(mac_tx_clk_2),
    .mac_rx_clk_2(mac_rx_clk_2),
    .data_tx_ready_2(data_tx_ready_2),
    .data_rx_data_2(data_rx_data_2),
    .data_rx_valid_2(data_rx_valid_2),
    .data_rx_eop_2(data_rx_eop_2),
    .data_rx_sop_2(data_rx_sop_2),
    .data_rx_error_2(data_rx_error_2),
    .pkt_class_data_2(pkt_class_data_2),
    .pkt_class_valid_2(pkt_class_valid_2),
    .gm_tx_d_2(gm_tx_d_2),
    .gm_tx_en_2(gm_tx_en_2),
    .gm_tx_err_2(gm_tx_err_2),
    .m_tx_d_2(m_tx_d_2),
    .m_tx_en_2(m_tx_en_2),
    .m_tx_err_2(m_tx_err_2),
    .ena_10_2(),
    .eth_mode_2(eth_mode_2));
    And I got warnings from compilation like:Ignored filter at triple_mac_constraints.sdc: clk could not be matched with a port
    Ignored filter at triple_mac_constraints.sdc:mac_tx_clk_0 could not be matched with a port.
    Ignored create_clock at triple_mac_constraints.sdc: Argument <> is an empty collection
    Almost all of the constraints were ignored due to naming problems.
    By the way, I didn't run any tcl before using the IP.
    Quartus generated a triple_mac_constraints.tcl and a
    triple_mac_nativelink.tcl with the IP.
    Do I need to run some scripts before starts using a IP core?
    I'm not an expert on this point, but I think there are mismatches between the top level signals and the names in the contraints file
    For example
    set CLK "clk" , but you clock is called sysclk in the top level
    set TX_CLK "tx_clk" , but this is tx_clk_0/_1/_2 at the top level
    and so on.
    The Megafunction Wizard generated a .v file for the IP. If I used the .v file of the IP as a top module and compile, it would work but if I instantiate the IP in my design module, all of the constraints were ignored.
    I'm wondering that might be because the hierarchy path in the generated sdc file is not set correctly. But I have tried all of the combinations like top.triple_mac_inst, etc.
    Does anyone have an idea about this...
    --- Quote Start ---
    For example
    and so on.
    --- Quote End ---
    But if I used the IP module as the top module, it would work.
    The IP module still use the name of tx_clk_0/_1/_2,etc.
