Need advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me.
I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v15. I write down code:LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
-- truth-table of full-adder
-- with three inputs: ci{carry_in}, a{first in} and b{second in}
-- and two ouputs: s{sum} and co{carry_out}
-- ci a b | s co
-- 0 0 0 | 0 0
-- 0 0 1 | 1 0
-- 0 1 0 | 1 0
-- 0 1 1 | 0 1
-- 1 0 0 | 1 0
-- 1 0 1 | 0 1
-- 1 1 0 | 0 1
-- 1 1 1 | 1 1
ENTITY full_add_1bit IS
PORT (
ci : IN STD_LOGIC;
a : IN STD_LOGIC;
b : IN STD_LOGIC;
s : OUT STD_LOGIC;
co : OUT STD_LOGIC
END full_add_1bit;
ARCHITECTURE b OF full_add_1bit IS
BEGIN
p0 : PROCESS(ci, a, b)
VARIABLE
aab,
aob,
axb,
sxc : STD_LOGIC;
BEGIN
aab := a AND b;
axb := a XOR b;
sxc := axb XOR ci;
s <= sxc;
IF ci = '0' THEN
co <= aab;
ELSIF ci = '1' THEN
aob := axb XOR aab; -- the same as (a OR b)
co <= aob;
END IF;
END PROCESS p0;
END b; but during compilation i recieves message --- Quote Start --- Warning (10631): VHDL Process Statement warning at full_add_1bit.vhd(30): inferring latch(es) for signal or variable "co", which holds its previous value in one or more paths through the process --- Quote End --- I follow the simple logic - let's compute new values then do all signal assignments and the question is question1 : does pressure on variables so need?! I rewrite architecture to new one, let's compiler do all work: ARCHITECTURE b1 OF full_add_1bit IS
BEGIN
VARIABLE
result_i : INTEGER;
VARIABLE
result_v : STD_LOGIC_VECTOR (0 TO 1);
BEGIN
result_i := CONV_INTEGER(a)+CONV_INTEGER(b)+CONV_INTEGER(ci);
result_v := CONV_STD_LOGIC_VECTOR (result_i, 2);
co <= result_v(0);
s <= result_v(1);
END PROCESS p0;
END b1; Finally i make schematic for this with 2mux1 blocks as for fun... in the attachments. never use schematic for establishing any equation - you waste your time. But result is the same with that scheme. question 2: how to find the way to good coding style?31 Replies
A slightly quirky one, I agree. However, the following code is confusing Quartus:
Using 'ELSE' covers all other cases. By using 'ELSIF' Quartus believes there may be some other paths it must handle - even though there aren't in this case. Change these lines to:IF ci = '0' THEN co <= aab; ELSIF ci = '1' THEN aob := axb XOR aab; -- the same as (a OR b) co <= aob; END IF;
I recommend you always use an ELSE at the end of conditional statements that infer combinational logic. Cheers, AlexIF ci = '0' THEN co <= aab; ELSE aob := axb XOR aab; -- the same as (a OR b) co <= aob; END IF; - Altera_Forum
thanks for advice.
An another comment on coding style - the conv_std_logic_vector and conv_integer functions come from the non-standard std_logic_unsigned and std_logic_arith packages. You shouldnt use them, as they are non-standard. You should use the numeric_std package instead. (and probably use appropriate types to avoid type conversion as much as possible - you can use non-std_logic_vector types in ports - like unsigned or signed type.).
thanks for advice
Ok. I know how to use UNSIGNED ports. I make an example:
I have question1 : When i write initial value for UNSIGNED like ... := "0" without prepand symbol 'X' ModelSim unable to start simulation (Error loading design and point to line number for port a). Which symbols allowed at the beggining? I think the code above can synthesis any combinatoral adder. I want some that work with clocking. question 2: why i reinvent adders, is there any class of ready function, where i can read about? question 3: If i instatiate my entity I am not sure about the length of result_v variable which n will be substituted. Thx in advance.LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.numeric_std.ALL; ENTITY full_adder_Nbit IS GENERIC ( N : POSITIVE := 4 ); PORT ( ci : IN STD_LOGIC := '0'; a : IN UNSIGNED (N-1 DOWNTO 0) := X"0"; b : IN UNSIGNED (N-1 DOWNTO 0) := X"0"; s : OUT UNSIGNED (N-1 DOWNTO 0) := X"0"; co : OUT STD_LOGIC := '0' ); END full_adder_Nbit; ARCHITECTURE b OF full_adder_Nbit IS BEGIN p0 : PROCESS(ci, a, b) VARIABLE result_v : UNSIGNED (0 TO N+1); BEGIN result_v := ('0' & a & '1') + ('0' & b & ci); co <= result_v(0); s <= result_v(1 TO N); END PROCESS p0; END b; - Altera_Forum
For your questions.
1. What you have specified is a default value if nothing is connected to it. But the value have assigned is only 4 bits long, so if N is anything other than 4, there will be an error. 2. With unsigned type, you have all the arithmetic functions, as you've already done. r <= a + b; But in your code, you have extended a by 1 bit correct, but then you also append '1' to the LSB. You need to write: result_v := ('0' & a) + ('0' & b) + ('0' & ci); -- if you get error about ambiguous types, write unsigned'('0' & ci); You also have an error in your code. result should be created as variable result_v : unsigned(N downto 0); and s should be sliced s <= result_v(N-1 downto 0); co <= result_v(N); 3. when you fix the direction errors, result_v will have a length of N+1. - Altera_Forum
I've changed as you wish. But I am confused what's wrong with my previous. I agree that no extra bit requried in variable , but the reverse order - i'm confused. I can only suggest that LSB is always at index 0 but I am not sure about it. If your advice is coming from code can be read clearly, i accept it.
ARCHITECTURE b OF full_adder_Nbit IS BEGIN p0 : PROCESS(ci, a, b) VARIABLE result_v : UNSIGNED (N DOWNTO 0); BEGIN result_v := ('0' & a ) + ('0' & b) + ('0' & ci); co <= result_v(N); s <= result_v(N-1 DOWNTO 0); END PROCESS p0; END b; - Altera_Forum
Ok. Another one example. If I make my adder synchronus. Will be my code suitable for real application?
I am very unsure does it really need to store output value in register and at the falling edge. I can drive it directly but what i get?! I'm also unsure about storing input values in registry/ Perhaps I need only do addtion when clock arrive. So as result I can write down FOUR different solutions: 1) no register at input and output, do result when clock transition from 0 to 1 arrive. 2) register at inputs and no register at output. 3) no register at input but at the output. 4) inputs and outputs have register. (as shown in code above). question 1. What will be the best solution, how it depends on application? question 2. Do I make transition to synchronus right?LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.numeric_std.ALL; ENTITY full_adder_Nbit IS GENERIC ( N : POSITIVE := 4 ); PORT ( clk : IN STD_LOGIC := '0'; ci : IN STD_LOGIC := '0'; a : IN UNSIGNED (N-1 DOWNTO 0) := X"0"; b : IN UNSIGNED (N-1 DOWNTO 0) := X"0"; s : OUT UNSIGNED (N-1 DOWNTO 0) := X"0"; co : OUT STD_LOGIC := '0' ); END full_adder_Nbit; ARCHITECTURE b OF full_adder_Nbit IS SIGNAL reg_a, reg_b, out_s : UNSIGNED (N-1 DOWNTO 0); SIGNAL reg_ci, out_co : STD_LOGIC; BEGIN p0 : PROCESS (clk) BEGIN IF rising_edge(clk) THEN reg_a <= a; reg_b <= b; reg_ci <= ci; END IF; END PROCESS p0; p1 : PROCESS(reg_ci, reg_a, reg_b) VARIABLE result_v : UNSIGNED (N DOWNTO 0); BEGIN result_v := ('0' & reg_a) + ('0' & reg_b) + ('0' & reg_ci); out_co <= result_v(N); out_s <= result_v(N-1 DOWNTO 0); END PROCESS p1; p2 : PROCESS (clk) BEGIN IF falling_edge(clk) THEN co <= out_co; s <= out_s; END IF; ENd PROCESS p2; END b; - Altera_Forum
in principle the addition (combinatorial only) will do the job.
registering inputs/outputs is a measure to achieve synchronous design and best fmax. The tradition is to register outputs only (not inputs) per module since then inputs received are already registered. Excluding very first paths at io which need to be registered - Altera_Forum
thank you, Kaz.
I think external inputs should lead to some state machine which do control for entire device or just for local module. if so i should develope a pulse generator with programmed delay and number of output cycle to provide internal clocks. But what type of state-machine to choose Melay or Moore?
