11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoOk. I know how to use UNSIGNED ports. I make an example:
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.numeric_std.ALL;
ENTITY full_adder_Nbit IS
GENERIC (
N : POSITIVE := 4
PORT (
ci : IN STD_LOGIC := '0';
a : IN UNSIGNED (N-1 DOWNTO 0) := X"0";
b : IN UNSIGNED (N-1 DOWNTO 0) := X"0";
s : OUT UNSIGNED (N-1 DOWNTO 0) := X"0";
co : OUT STD_LOGIC := '0'
END full_adder_Nbit;
ARCHITECTURE b OF full_adder_Nbit IS
BEGIN
p0 : PROCESS(ci, a, b)
VARIABLE
result_v : UNSIGNED (0 TO N+1);
BEGIN
result_v := ('0' & a & '1') + ('0' & b & ci);
co <= result_v(0);
s <= result_v(1 TO N);
END PROCESS p0;
END b; I have question1 : When i write initial value for UNSIGNED like ... := "0" without prepand symbol 'X' ModelSim unable to start simulation (Error loading design and point to line number for port a). Which symbols allowed at the beggining? I think the code above can synthesis any combinatoral adder. I want some that work with clocking. question 2: why i reinvent adders, is there any class of ready function, where i can read about? question 3: If i instatiate my entity I am not sure about the length of result_v variable which n will be substituted. Thx in advance.
