marcorig
1 year agoLPM DIVIDE behaves differently between simulation and implementation
I have implemented a divider in a custom VHDL module in order to replace the instances of the LPM_DIVIDE IPs in my project. I've then checked the functionality of my module against the LPM_DIVIDE and...
ShengN_altera
1 year agoHi,
I observe that if change pipeline number, the signal tap results will be different.
I suspect is the timing issue. Could you add .sdc file to check is that the timing pass? Make sure the timing is pass.
Sheng
