marcorig
1 year agoLPM DIVIDE behaves differently between simulation and implementation
I have implemented a divider in a custom VHDL module in order to replace the instances of the LPM_DIVIDE IPs in my project. I've then checked the functionality of my module against the LPM_DIVIDE and...
ShengN_altera
1 year agoHi,
For signal tap, i can get the same result as you.
However for simulation, i use your testbench and modelsim but i can't get the same result as you check attached pic. It keeps the same at FFFFFFEC78000000. Is there anything i miss?
Sheng
