marcorig
1 year agoLPM DIVIDE behaves differently between simulation and implementation
I have implemented a divider in a custom VHDL module in order to replace the instances of the LPM_DIVIDE IPs in my project. I've then checked the functionality of my module against the LPM_DIVIDE and...
marcorig
1 year agoHi Sheng, thank you for the answer. The 0xFF..FFF4FF (quotient) output is under 010139F1A9h (denominator) and 7FFFFA7872h (numerator) in the simulation because I've simulated the divider standalone in order to check its behavior feeding the IP only with those operands. In HW the divider is part of a more complex design and it is fed in pipeline with a stream of operands. That's the reason why in SignalTap you also see the subsequent operands, but the 0xFF..FFF4FE is the result of the first two operands of the stream, that are the same of the simulation:
