randomuser900's avatar
randomuser900
Icon for New Member rankNew Member
1 day ago
License for Questa Starter Edition will not work
I tried looking up other posts for this issue, but none of the answers people gave helped. This is the error that shows up after I downloaded the license and set SALT_LICENSE_SERVER to point to it.
I tried creating and pointing LM_LICENSE_FILE and MGLS_LICENSE_FILE too. It didn't work either. The address is correct too. I don't know what is going on
  • I finally got it to work. I pointed SALT_LICENSE_SERVER to the license file in both user variables and system variables, and that fixed the problem.
  • Hi randomuser900,
    May I know the Modelsim/ QuestaSim edition and version that you are currently using? And also, Quartus Edition and version installed in your machine?
    Here are several suggestions you may try on:
    1. Upgrade the Siemens daemon to saltd v11.19.5 if you're on version 2024.1. You may refer to the following KDB article: https://community.altera.com/kb/knowledge-base/error--flexlm-version-of-vendor-daemon-is-too-old/342390
    2. Verify the MGLS_LICENSE_FILE environment variable. Since MGLS_LICENSE_FILE takes precedence, please ensure it points to the correct license path or port@hostname. It is generally recommended to define only one license source unless you are using multiple Siemens EDA products. For more information, refer to Section 4.1.2.1, "QuestaSim Software License-Specific Considerations": https://docs.altera.com/r/docs/683680/24.1/altera-high-level-synthesis-compiler-pro-edition-getting-started-guide/lm_license_file-environment-variable
    3. Confirm the license was generated for the correct NIC ID / host — regenerate at SSLC if the machine changed. You may refer to https://community.altera.com/kb/knowledge-base/why-does-questa-license-fail-to-install-in-the-quartus%C2%AE-prime-lite-edition-softw/341018
    Kindly let me know your findings, and I will be happy to assist further. Thank you.
    ZiYingE_Altera
    • ZiYingE_Altera's avatar
      ZiYingE_Altera
      Hi randomuser900
      Thank you for the update. Glad that your issue is resolved. I will set this case to close status.
      We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
      ZiYingE_Altera
    • randomuser900's avatar
      randomuser900
      I am using Quartus Lite 25.1 and Questa Starter 25.1
      I tried setting MGLS_LICENSE_FILE to point to the Questa license file, and it just gave the following error:
      Yes, the license is correct. I tried regenerating it again, but it still doesn't work
