License for Questa Starter Edition will not work
- 1 month ago
I finally got it to work. I pointed SALT_LICENSE_SERVER to the license file in both user variables and system variables, and that fixed the problem.
Hi randomuser900,
May I know the Modelsim/ QuestaSim edition and version that you are currently using? And also, Quartus Edition and version installed in your machine?
Here are several suggestions you may try on:
1. Upgrade the Siemens daemon to saltd v11.19.5 if you're on version 2024.1. You may refer to the following KDB article: https://community.altera.com/kb/knowledge-base/error--flexlm-version-of-vendor-daemon-is-too-old/342390
2. Verify the MGLS_LICENSE_FILE environment variable. Since MGLS_LICENSE_FILE takes precedence, please ensure it points to the correct license path or port@hostname. It is generally recommended to define only one license source unless you are using multiple Siemens EDA products. For more information, refer to Section 4.1.2.1, "QuestaSim Software License-Specific Considerations": https://docs.altera.com/r/docs/683680/24.1/altera-high-level-synthesis-compiler-pro-edition-getting-started-guide/lm_license_file-environment-variable
3. Confirm the license was generated for the correct NIC ID / host — regenerate at SSLC if the machine changed. You may refer to https://community.altera.com/kb/knowledge-base/why-does-questa-license-fail-to-install-in-the-quartus%C2%AE-prime-lite-edition-softw/341018
Kindly let me know your findings, and I will be happy to assist further. Thank you.
ZiYingE_Altera
- randomuser9001 month ago
I am using Quartus Lite 25.1 and Questa Starter 25.1
I tried setting MGLS_LICENSE_FILE to point to the Questa license file, and it just gave the following error:
Yes, the license is correct. I tried regenerating it again, but it still doesn't work
- ZiYingE_Altera1 month ago
Contributor
Hi randomuser900,
Thank you for the update. Glad that your issue is resolved. I will set this case to close status.
We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
ZiYingE_Altera- sselhorst1 month ago
I am having the same issue randomuser900 was having. I have Quartus Prime Pro 25.3 with its Questa (the free version) installed. I have also installed Quartus patch 25.3-0.27. The Questa license from the SSLC matches the NIC ID on my laptop. SALT_LICENSE_SERVER points to the license file. I created a system SALT_LICENSE_SERVER environmental variable also pointing the same license file, which randomuser900 reported fixed the issue. I have tried the license file on both my c: and my d: drive. Nothing has worked yet. I placed the license file in d:\license\ directory. Please help.
When I start Quest by itself, which is way I will use it.
When I start Questa from Quartus
- sstrell1 month ago
Your screenshot is showing that the license should be on c:\License\ but you say the file is on your d: drive.
