JTAG - USB blaster 2 does not identify the FPGA
I am using the Programmer to load the FPGA. This is Quartus 23.4
When I select USB-1 and click on "Auto Detect", it shows me a list of options for the FPGAs.
Issue: FPGA that I am using is not shown in this list. I am using FPGA with part number AGIB027R31A2E2VB (99C7XH)
Please let me know how to proceed. I want to program the FPGA and then run transceiver toolkit for BER test
Ranjith
Yeah, it doesn't really matter which device you pick in the auto detect dialog (which is something that has confused me for years). When you select your programming file, it will get the correct device from that.
- FvM
JTAG ID and FPGA chip are the same for different packages. Load the programming file, it should show the projected FPGA.
- sstrell
- Ranjith21
- cfkd
Hi Ranjith,
Thank you for your question. I see you have the solution; could you confirm if it is good to close this case?
Chee
- Ranjith21
Hi Chee,
Yes, the marked solution works. This case can be closed.
Thanks,Ranjith
- cfkd
Hi Ganesh,
Thank you for your confirmation. We would like to inform you that we will now move this discussion to community support. If you have any new questions or concerns, we recommend starting a new thread to receive assistance from Intel experts. Alternatively, if you don't have any further inquiries, our community users will be here to help you in this thread. Your understanding is greatly appreciated.
Chieru
