I/O assignment analysis fail Quartus Prime Lite 23.1 for CycloneV
Hi everyone, currently I am creating my own SoC system. I have run Analysis and Synthesis successfully, then I run tcl script hps_sdram_p0_parameters.tcl and hps_sdram_p0_pin_assignments.tcl respectively. After that, I run I/O assignment analysis and receive this error:
Critical Warning (169085): No exact pin location assignment(s) for 120 pins of 172 total pins. For the list of pins please refer to the I/O Assignment Warnings table in the fitter report. Critical Warning (174073): No exact pin location assignment(s) for 1 RUP, RDN, or RZQ pins of 1 total RUP, RDN or RZQ pins Info (174074): RUP, RDN, or RZQ pin HPS_DDR3_RZQ not assigned to an exact location on the device Info (184020): Starting Fitter periphery placement operations Error (14996): The Fitter failed to find a legal placement for all periphery components Error (14986): After placing as many components as possible, the following errors remain: Error (175001): The Fitter cannot place 30 pins. Info (14596): Information about the failing component(s): Info (175028): The pin name(s): HPS_DDR3_DQ[8], HPS_DDR3_DQ[9], HPS_DDR3_DQ[10], HPS_DDR3_DQ[11], HPS_DDR3_DQ[12] and other 25 pins Info (15647): These pins are in a group of 30 components with similar legality requirements Error (16234): No legal location could be found out of 176 considered location(s). Reasons why each location could not be used are summarized below: Error (184016): There were not enough single-ended bidirectional pin locations available (91 locations affected) Info (175029): Y9. Already placed at this location: pin altera_reserved_tdo Info (175015): The I/O pad altera_reserved_tdo is constrained to the location PIN_Y9 due to: JTAG placement Info (14709): The constrained I/O pad is contained within this pin Info (175029): AC7. Already placed at this location: pin altera_reserved_tms Info (175015): The I/O pad altera_reserved_tms is constrained to the location PIN_AC7 due to: JTAG placement Info (14709): The constrained I/O pad is contained within this pin Info (175029): AB5. Already placed at this location: pin altera_reserved_tck Info (175015): The I/O pad altera_reserved_tck is constrained to the location PIN_AB5 due to: JTAG placement Info (14709): The constrained I/O pad is contained within this pin Info (175029): W10. Already placed at this location: pin altera_reserved_tdi Info (175015): The I/O pad altera_reserved_tdi is constrained to the location PIN_W10 due to: JTAG placement Info (14709): The constrained I/O pad is contained within this pin Info (175029): Y8. Already placed at this location: pin HDMI_TX_D[3] Info (175015): The I/O pad HDMI_TX_D[3] is constrained to the location PIN_Y8 due to: User Location Constraints (PIN_Y8) Info (14709): The constrained I/O pad is contained within this pin Info (175029): Y4. Already placed at this location: pin HDMI_TX_D[9] Info (175015): The I/O pad HDMI_TX_D[9] is constrained to the location PIN_Y4 due to: User Location Constraints (PIN_Y4) Info (14709): The constrained I/O pad is contained within this pin Info (175029): W8. Already placed at this location: pin HDMI_TX_D[2] Info (175015): The I/O pad HDMI_TX_D[2] is constrained to the location PIN_W8 due to: User Location Constraints (PIN_W8) Info (14709): The constrained I/O pad is contained within this pin Info (175029): Y5. Already placed at this location: pin HDMI_TX_D[7] Info (175015): The I/O pad HDMI_TX_D[7] is constrained to the location PIN_Y5 due to: User Location Constraints (PIN_Y5) Info (14709): The constrained I/O pad is contained within this pin Info (175029): T8. Already placed at this location: pin HDMI_TX_HS Info (175015): The I/O pad HDMI_TX_HS is constrained to the location PIN_T8 due to: User Location Constraints (PIN_T8) Info (14709): The constrained I/O pad is contained within this pin Info (175029): AB4. Already placed at this location: pin HDMI_TX_D[11] Info (175015): The I/O pad HDMI_TX_D[11] is constrained to the location PIN_AB4 due to: User Location Constraints (PIN_AB4) Info (14709): The constrained I/O pad is contained within this pin Info (175029): AA4. Already placed at this location: pin HDMI_I2C_SDA Info (175015): The I/O pad HDMI_I2C_SDA is constrained to the location PIN_AA4 due to: User Location Constraints (PIN_AA4) Info (14709): The constrained I/O pad is contained within this pin Info (175029): U10. Already placed at this location: pin HDMI_I2C_SCL Info (175015): The I/O pad HDMI_I2C_SCL is constrained to the location PIN_U10 due to: User Location Constraints (PIN_U10) Info (14709): The constrained I/O pad is contained within this pin Info (175029): and 79 more locations not displayed Error (179008): Could not find enough available I/O pin locations that can be configured to use a VCCIO voltage of 2.5V (85 locations affected) Info (175029): U9 Info (175029): V10 Info (175029): AD4 Info (175029): AC4 Info (175029): AA11 Info (175029): AE6 Info (175029): Y11 Info (175029): AD5 Info (175029): AF4 Info (175029): W11 Info (175029): AF7 Info (175029): AH3 Info (175029): and 73 more locations not displayed Info (184021): Fitter periphery placement operations ending: elapsed time is 00:00:01 Info (11798): Fitter preparation operations ending: elapsed time is 00:00:18 Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Warning (169064): Following 60 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results Info (169065): Pin HDMI_I2S has a permanently disabled output enable Info (169065): Pin HDMI_LRCLK has a permanently disabled output enable Info (169065): Pin HDMI_MCLK has a permanently disabled output enable Info (169065): Pin HDMI_SCLK has a permanently disabled output enable Info (169065): Pin HPS_CONV_USB_N has a permanently disabled output enable Info (169065): Pin HPS_ENET_INT_N has a permanently disabled output enable Info (169065): Pin HPS_ENET_MDIO has a permanently disabled output enable Info (169065): Pin HPS_GSENSOR_INT has a permanently disabled output enable Info (169065): Pin HPS_I2C0_SCLK has a permanently disabled output enable Info (169065): Pin HPS_I2C0_SDAT has a permanently disabled output enable Info (169065): Pin HPS_I2C1_SCLK has a permanently disabled output enable Info (169065): Pin HPS_I2C1_SDAT has a permanently disabled output enable Info (169065): Pin HPS_KEY has a permanently disabled output enable Info (169065): Pin HPS_LED has a permanently disabled output enable Info (169065): Pin HPS_LTC_GPIO has a permanently disabled output enable Info (169065): Pin HPS_SD_CMD has a permanently disabled output enable Info (169065): Pin HPS_SD_DATA[0] has a permanently disabled output enable Info (169065): Pin HPS_SD_DATA[1] has a permanently disabled output enable Info (169065): Pin HPS_SD_DATA[2] has a permanently disabled output enable Info (169065): Pin HPS_SD_DATA[3] has a permanently disabled output enable Info (169065): Pin HPS_SPIM_SS has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[0] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[1] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[2] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[3] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[4] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[5] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[6] has a permanently disabled output enable Info (169065): Pin HPS_USB_DATA[7] has a permanently disabled output enable Info (169065): Pin HDMI_I2C_SCL has a permanently enabled output enable Info (169065): Pin HPS_DDR3_DQ[8] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[9] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[10] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[11] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[12] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[13] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[14] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[15] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[16] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[17] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[18] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[19] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[20] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[21] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[22] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[23] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[24] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[25] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[26] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[27] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[28] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[29] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[30] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQ[31] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_N[1] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_N[2] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_N[3] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_P[1] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_P[2] has a permanently disabled output enable Info (169065): Pin HPS_DDR3_DQS_P[3] has a permanently disabled output enable Warning (169069): Following 72 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results Info (169070): Pin HPS_DDR3_ADDR[13] has GND driving its datain port Info (169070): Pin HPS_DDR3_ADDR[14] has GND driving its datain port Info (169070): Pin HPS_DDR3_DM[1] has GND driving its datain port Info (169070): Pin HPS_DDR3_DM[2] has GND driving its datain port Info (169070): Pin HPS_DDR3_DM[3] has GND driving its datain port Info (169070): Pin HPS_ENET_GTX_CLK has GND driving its datain port Info (169070): Pin HPS_ENET_MDC has GND driving its datain port Info (169070): Pin HPS_ENET_TX_DATA[0] has GND driving its datain port Info (169070): Pin HPS_ENET_TX_DATA[1] has GND driving its datain port Info (169070): Pin HPS_ENET_TX_DATA[2] has GND driving its datain port Info (169070): Pin HPS_ENET_TX_DATA[3] has GND driving its datain port Info (169070): Pin HPS_ENET_TX_EN has GND driving its datain port Info (169070): Pin HPS_SD_CLK has GND driving its datain port Info (169070): Pin HPS_SPIM_CLK has GND driving its datain port Info (169070): Pin HPS_SPIM_MOSI has GND driving its datain port Info (169070): Pin HPS_UART_TX has GND driving its datain port Info (169070): Pin HPS_USB_STP has GND driving its datain port Info (169070): Pin HPS_CONV_USB_N has VCC driving its datain port Info (169070): Pin HPS_ENET_INT_N has VCC driving its datain port Info (169070): Pin HPS_ENET_MDIO has VCC driving its datain port Info (169070): Pin HPS_GSENSOR_INT has VCC driving its datain port Info (169070): Pin HPS_I2C0_SCLK has VCC driving its datain port Info (169070): Pin HPS_I2C0_SDAT has VCC driving its datain port Info (169070): Pin HPS_I2C1_SCLK has VCC driving its datain port Info (169070): Pin HPS_I2C1_SDAT has VCC driving its datain port Info (169070): Pin HPS_KEY has VCC driving its datain port Info (169070): Pin HPS_LED has VCC driving its datain port Info (169070): Pin HPS_LTC_GPIO has VCC driving its datain port Info (169070): Pin HPS_SD_CMD has VCC driving its datain port Info (169070): Pin HPS_SD_DATA[0] has VCC driving its datain port Info (169070): Pin HPS_SD_DATA[1] has VCC driving its datain port Info (169070): Pin HPS_SD_DATA[2] has VCC driving its datain port Info (169070): Pin HPS_SD_DATA[3] has VCC driving its datain port Info (169070): Pin HPS_SPIM_SS has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[0] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[1] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[2] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[3] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[4] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[5] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[6] has VCC driving its datain port Info (169070): Pin HPS_USB_DATA[7] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[8] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[9] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[10] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[11] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[12] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[13] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[14] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[15] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[16] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[17] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[18] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[19] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[20] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[21] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[22] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[23] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[24] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[25] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[26] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[27] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[28] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[29] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[30] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQ[31] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_N[1] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_N[2] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_N[3] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_P[1] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_P[2] has VCC driving its datain port Info (169070): Pin HPS_DDR3_DQS_P[3] has VCC driving its datain port Info (169186): Following groups of pins have the same dynamic on-chip termination control Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[0] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[1] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[2] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[3] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[4] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[5] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[6] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|delayed_oct Info (169066): Type bi-directional pin HPS_DDR3_DQ[7] uses the SSTL-15 Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|diff_dtc_bar Info (169066): Type bi-directional pin HPS_DDR3_DQS_N[0] uses the Differential 1.5-V SSTL Class I I/O standard Info (169185): Following pins have the same dynamic on-chip termination control: msdma_fpga:u0|msdma_fpga_hps_0:hps_0|msdma_fpga_hps_0_hps_io:hps_io|msdma_fpga_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|hps_sdram_p0_acv_hard_io_pads:uio_pads|hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|diff_dtc Info (169066): Type bi-directional pin HPS_DDR3_DQS_P[0] uses the Differential 1.5-V SSTL Class I I/O standard Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number. Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 7 errors, 26 warnings Error: Peak virtual memory: 5552 megabytes Error: Processing ended: Sat Apr 27 03:20:34 2024 Error: Elapsed time: 00:00:45 Error: Total CPU time (on all processors): 00:00:37
What can I do to solve this problem?
The error due to the width mismatch between the ports of top module DE10_NANO_SoC_GHRD.v and the ports of msdma_fpga.
Modify the lines below in DE10_NANO_SoC_GHRD.v then there'll be no error anymore after running the tcl script and I/O assignment analysis:
Line 29: output [/*14*/12: 0] HPS_DDR3_ADDR,
Line 37: inout [/*31*/7: 0] HPS_DDR3_DQ,
Line 39: inout /*[ 3: 0]*/ HPS_DDR3_DQS_P,
Sheng
- sstrell
It looks like you may have made manual pin assignments to pins dedicated to the HPS, like those HDMI signals as well as assignments to the dedicated JTAG pins. What does your Pin Planner look like?
- minhlee
Hi @strell, here is my zip file contain my project. Basically, I am currently learning how to use mSGDMA core from this tutorial: https://blog.reds.ch/?p=835 to access DRAM from FPGA in my de10 nano.
- KennyT_altera
We will need sometime to look into the design. stay tune
- ShengN_altera
Sheng
- minhlee
Nice, thank you very much.
