11 years agoImplementing PCIe with qsys in quartus 14.0
I am trying to generate PCIe from IP catalog, and generated its qsys system. Targeting Stratix V 5SGXEA7N2F40C2. During compilation run its passing Analysis & Synthesis, Fitter, Assembler but when I check compilation report, for 'TimeQuest Timing Analyzer' it shows error for Unconstrained Paths. But Assembler stage passed and generated .sof programming file. So why I am getting that error? I did not change anything in the design/constraint files, design is default generated out of Quartus. Is that error real or can be ignored and I can program the .sof?
Also in left hand side - Task window (where it shows the Flow progress) it does not show the error. Please find the attached screenshot. Looking forward for the reply ASAP, thank you!
