11 years agoOk, got it here is the Report pane. For unconstrained clock I have added its constraint to sdc so it is solved but it still complaining about many unconstrained IO ports and paths. So if I am generating design out of quartus then why all these constraint errors, isn't it should have everything auto generated for default design and run though without errors?
So just to verify: if I have created pcie ip through ip catalog and then to create its example design I have to follow the qsys flow right, that is the only way?
