11 years ago --- Quote Start --- I ran TimeQuest to check the unconstrained paths but it does not report any, that's why I am not able to understand what is wrong or if I am following correct things. Below is the TimeQuest snapshot, I am new to Quartus and I hope I am doing the correct thing. --- Quote End --- You're looking at the wrong place in the TimeQuest GUI. Once you run that task, there will be several folders generated in the GUI near the top-left. Click through those folders and you'll see the paths identified. Cheers, Dave
