Implementation and Timing of Reset Circuits
Most circuit designs employing FPGAs and ASICs are synchronous systems using a large number of flip-flops or registers. It is usually important that these synchronous elements are capable of starting or being returned to a known state (logic ‘1’ or ‘0’). This function is normally handled by a reset. There are usually one or more reset signals that are brought into the device and used, alone or in conjunction with additional circuitry to perform this function. This Tech Note examines the various types of resets; synchronous, asynchronous, and synchronized asynchronous with respect to their advantages and disadvantages, various techniques of implementation in FPGAs, and their proper timing analysis in Altera’s TimeQuest timing analysis engine.
Synchronous circuits are typically reset with one of two types of resets; synchronous or asynchronous resets. Synchronous resets are frequency synchronous with the clock domain of the registers they reset. Asynchronous resets by nature will arrive at the registers they are affecting with a non-deterministic timing relationship to the clock domain of the registers. Because of this, it is difficult to time these types of resets. A third category or resets is discussed here which, for the lack of a better name, will be referred to as synchronized asynchronous resets. These resets have some of the benefits of synchronous resets without some of their disadvantages, and they also avoid some of the pitfalls that can be associated with purely asynchronous resets. As shall be shown, for most situations, synchronized asynchronous resets are the preferred method when designing FPGA circuits.
