I am almost certain that my Quartus II web 13.1 program creates RTL schematics with errors in them. (I have not upgraded the installation afterwards because my computer is offline!).
Please see next screencopy that shows the wrong 2'h1 and 2'h2 markings (they should be exchange) in the Mux4to1 example. Also the RTL schematic of the 4to2 Mux makes no sense to me. Can you please explain me if I'm correct and if not how to intepret the
- KhaiChein_Y_Intel
You mentioned that this problem was already solved in the past by upgrading the 13.1 Quartus II version. May I know what is the version that you did not see the error?
KhaiY
- AVanB3
The Quartus version I use on my Windows 7 desktop is Quartus II 32-bit version 13.1.4 Build 182 03/12/2014 SJ Web Edition. And is the version that failed to compile above example and others where Xilinx Ise 14.6 had no problem with to create the right RTL circuits.
- AVanB3
So above mentioned Quartus not compiling where Xilinx ISE perefectly compiles is a new problem that was not solved yet. Only a previously noticed wrong marking error/bug in the RTL presentation was solved after upgrading to present version.
- AVanB3
And below is another example of VHDL code that perfectly works in Xilinx ISE (not Spartan3E but with higher FPGA's only!) but never works in Quartus:
--BRAM_16x2 page194 Vaibbhav Taraate.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity BRAM_16x2 is
port (q_out : out std_logic_vector (1 downto 0);
write_en : in std_logic;
clk: in std_logic;
d_in: in std_logic_vector (1 downto 0);
a_in: in std_logic_vector (3 downto 0));
end BRAM_16x2;
architecture BRAM_arch of BRAM_16x2 is
component BRAM_16x1S is
port(O : out std_logic;
D: in std_logic;
A3, A2, A1, A0: in std_logic;
WE, W_CLK: in std_logic);
end component;
begin
U0: BRAM_16x1S port map (O =>q_out(0), WE =>write_en, W_CLK =>clk, D =>d_in(0),
A0 =>a_in(0), A1 =>a_in(1), A2 =>a_in(2), A3 =>a_in(3));
U1: BRAM_16x1S port map (O =>q_out(1), WE => write_en, W_CLK => clk, D =>d_in(1),
end BRAM_arch;
--------------Which gives following error rapport in Quartus II 13.1 but works in ISE! -------
Warning (20028): Parallel compilation is not licensed and has been disabled
Warning (12125): Using design file bram_16x2.vhd, which is not specified as a design file for the current project, but contains definitions for 2 design units and 1 entities in project
Info (12022): Found design unit 1: BRAM_16x2-BRAM_arch
Info (12023): Found entity 1: BRAM_16x2
Error (12006): Node instance "U0" instantiates undefined entity "BRAM_16x1S"
Error (12006): Node instance "U1" instantiates undefined entity "BRAM_16x1S"
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Error: Peak virtual memory: 393 megabytes
Error: Processing ended: Mon May 11 17:13:47 2020
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 2 warnings
- KhaiChein_Y_Intel
I understand that the original RTL mismatch problem is solved by upgrading the software to Quartus II 32-bit version 13.1.4 Build 182 03/12/2014 SJ Web Edition.
For the new error below, can you share the full design.QAR file for investigation? To create the design, click on Project > Archive Project > Archive
KhaiY
- KhaiChein_Y_Intel
Do you have any updates?
KhaiY
- AVanB3
No sadly I have just quit for the time being unable to solve the Quartus II issues presented above. I also use Xilinx that works where Quartus completely failed in the given examples. And another problem arose that made me get stuck in my Quartus II version in that it apparently doesn't automatically use the simulation testfile that was made for a 4 to 1 Mux and its already in the VHDL file put in In- and output declarations and the to simulate input data. It apparently never is intuitive which would make starting to use Quartus much easier. Never knowing (all off-line without on-line connection) how to use Quartus II correctly. Apparently I still have to manually set all input and outputs before any simulation is possible in Quartus? I keep reading books on VHDL , the best one yet was Vaibbhav Taraate's PLD Based Design with VHDL, but still I need another book on how to use Quartus. (the BRAM examples and other examples from that book failed in Quartus but worked in Xilinx ISE!). So at the moment I just keep on reading other books on VHDL too and didn't get any further where Quartus is concerned.
- KhaiChein_Y_Intel
Do you still see the error below? If yes, can you provide the design.qar for investigation?
For the new question on simulation: It apparently doesn't automatically use the simulation testfile that was made for a 4 to 1 Mux and its already in the VHDL file put in In- and output declarations and the to simulate input data. can you open a new forum post to make sure that there is only one question in one post? This helps to reduce confusion to the other users who have the same error and helps them to find the solution to each of the error/question easily.
KhaiY
- AVanB3
Sadly even saving the QAR file of the BRAM16x2 example failed to complete successfully. Therefore I also included the errorlog files into a combined rar file. Hereby added. And I will try to open the Quartus II simulation question into the correct Forum links later on.
- KhaiChein_Y_Intel
The rar file is corrupted. Could you reattach?
KhaiY
- AVanB3
Hi KhaiY, I tried to login on the Intel page to answer but the URL somehow was rejected. See attached screencopy. Therefore I answer you by using my mail for replying. (I used my Opera browser when that error page generated). I tested my supposed 'corrupted' attachment file and was completely able to open and extract all single files. So I think it is the by the Quartus II program generated files that make them unusable? Because as said I got an error warning that said the program couldn't completely generate the files because the BRAM16x1S/16x2 VHDL file wasn't entirely successfully compiled. (Note that Xilinx ISE 14.6 had no problem with this same VHDL file!). I can resend you the files again but I think that it will make no difference when Quartus fails to completely compile again? Thanks. Albert.
- KhaiChein_Y_Intel
Hi Albert,
Can you send the entire project directory in ZIP?
KhaiY
