SHung4's avatar
SHung4
8 years ago
How to use MACRO on altera modelsim
I add a MACRO on Setting-compiler setting-Verilog HDL input, and it works.
But when I run RTL sim by altera modelsim, it seem that it don't use the MACRO. What is the right way to use MACRO on altera modelsim, thanks.
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    In the Transcript window
    ->do <file name >.do
    Will run the macro.
    For more information refer below links
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
    http://home.eng.iastate.edu/~zzhang/courses/cpre581-f05/resources/modelsim.pdf
    Anand Raj Shankar
  • SHung4's avatar
    SHung4
    I write the code in verilog file like this:
    `ifdef FPGA
    `endif​
    And I can use Setting-compiler setting-Verilog HDL input to add a macro FPGA when synthesis.
    But I find that it don't work when run RTL-simulation.
    AnandRaj_S_Intel
    +define+<macro_name>[=<macro_text>]
    I have used simple example
    ########################CODE##########################
    module and_op (a, b, c);
    output a;
    input b, c;
    `ifdef behavioral
    wire a = b & c;
    `else
    or a1 (a,b,c);
    `endif
    endmodule
    ##########################CODE####################
    ​vlog +define+behavioral -work work and_op.v
    Anand Raj Shankar
  • SHung4's avatar
    SHung4
    Is there any method to add some setting on Quartus, so that I can push "Tools/Run Simulation/RTL Simulation" to run simulation?
    AnandRaj_S_Intel
    Yes,
    We can have simple .do script to set the simulation environment(macro enabled).
    To launch simulation from Quartus.
    Assignments->settings->EDA tool Settings->simulation->tool name Modelsim-Altera ->select the option "script to compile test bench" -> input the .do with the macro which you want enable.
    To run the simulation from Quartus
    Tools->Run Simulation Tools->RTL Simulations.
    Refer image for more information.
    I have used about code with simple .do file .
    ------------.do---------------
    vlog +define+behavioral -work work C:/......./macro/and_op.v
    Which will launch Modelsim and run simulation for the enabled macro.
    Anand Raj Shankar
