How to use MACRO on altera modelsim
Yes,
We can have simple .do script to set the simulation environment(macro enabled).
To launch simulation from Quartus.
Assignments->settings->EDA tool Settings->simulation->tool name Modelsim-Altera ->select the option "script to compile test bench" -> input the .do with the macro which you want enable.
To run the simulation from Quartus
Tools->Run Simulation Tools->RTL Simulations.
Refer image for more information.
I have used about code with simple .do file .
------------.do---------------
vlog +define+behavioral -work work C:/......./macro/and_op.v
Which will launch Modelsim and run simulation for the enabled macro.
Anand Raj Shankar
