16 years agoHow to initialize content of a RAM without using Megawizard
Hello world,
Here is my problem. I would like to initialize the content of a RAM block with an external text file without using the megawizard plugin. The following VHDL is working correctly in Xilinx synthetizer (XST). the xst synthetizer create the netlist by including the RAM Block and the RAM is initialized with the content of the ram_init.txt file. In quartus, the synthetizer create the netlist by implementing a RAM block (altsyncram) but the RAM block is not initialized. When I look at the tdf file created during the synthesis, the RAM is initialized with the file ram_init.ram0_ram_init_bcaa821.hdl.mif in database (db) folder and unfortunately, this files is full of 0. Is somebody know how to fix this??? Br --------------------------------- Code of the source file:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use std.textio.all;
entity ram_init is
port(
-- RAM A interface
rama_clk : in std_logic;
rama_we : in std_logic;
rama_addr : in std_logic_vector(5 downto 0);
rama_din : in std_logic_vector(31 downto 0);
rama_dout : out std_logic_vector(31 downto 0));
end entity ram_init;
architecture syn of ram_init is
type RamType is array(0 to 63) of bit_vector(31 downto 0);
impure function InitRamFromFile (RamFileName : in string) return RamType is
FILE RamFile : text is in RamFileName;
variable RamFileLine : line;
variable RAM : RamType;
begin
for I in RamType'range loop
readline (RamFile, RamFileLine);
read (RamFileLine, RAM(I));
end loop;
return RAM;
end function;
signal RAM : RamType := InitRamFromFile("ram_init.txt");
begin
rama_proc:
process (rama_clk)
begin
if rama_clk'event and rama_clk = '0' then
if rama_we = '1' then
RAM(conv_integer(rama_addr)) <= to_bitvector(rama_din);
end if;
rama_dout <= to_stdlogicvector(RAM(conv_integer(rama_addr)));
end if;
end process;
Content of ram_init.txt
00001111000011110000111100001111
01001010001000001100000010000100
00000000001111100000000001000001
11111101010000011100010000100100
Content of the mfi generated file:
-- begin_signature
-- ram_init
-- end_signature
WIDTH=32;
DEPTH=64;
ADDRESS_RADIX=UNS;
DATA_RADIX=BIN;
CONTENT BEGIN
63 : 00000000000000000000000000000000;
62 : 00000000000000000000000000000000;
61 : 00000000000000000000000000000000;
60 : 00000000000000000000000000000000;
59 : 00000000000000000000000000000000;
58 : 00000000000000000000000000000000;
57 : 00000000000000000000000000000000;
56 : 00000000000000000000000000000000;
55 : 00000000000000000000000000000000;
54 : 00000000000000000000000000000000;
53 : 00000000000000000000000000000000;
52 : 00000000000000000000000000000000;
51 : 00000000000000000000000000000000;
50 : 00000000000000000000000000000000;
49 : 00000000000000000000000000000000;
48 : 00000000000000000000000000000000;
47 : 00000000000000000000000000000000;
46 : 00000000000000000000000000000000;
45 : 00000000000000000000000000000000;
44 : 00000000000000000000000000000000;
43 : 00000000000000000000000000000000;
42 : 00000000000000000000000000000000;
41 : 00000000000000000000000000000000;
40 : 00000000000000000000000000000000;
39 : 00000000000000000000000000000000;
38 : 00000000000000000000000000000000;
37 : 00000000000000000000000000000000;
36 : 00000000000000000000000000000000;
35 : 00000000000000000000000000000000;
34 : 00000000000000000000000000000000;
33 : 00000000000000000000000000000000;
32 : 00000000000000000000000000000000;
31 : 00000000000000000000000000000000;
30 : 00000000000000000000000000000000;
29 : 00000000000000000000000000000000;
28 : 00000000000000000000000000000000;
27 : 00000000000000000000000000000000;
26 : 00000000000000000000000000000000;
25 : 00000000000000000000000000000000;
24 : 00000000000000000000000000000000;
23 : 00000000000000000000000000000000;
22 : 00000000000000000000000000000000;
21 : 00000000000000000000000000000000;
20 : 00000000000000000000000000000000;
19 : 00000000000000000000000000000000;
18 : 00000000000000000000000000000000;
17 : 00000000000000000000000000000000;
16 : 00000000000000000000000000000000;
15 : 00000000000000000000000000000000;
14 : 00000000000000000000000000000000;
13 : 00000000000000000000000000000000;
12 : 00000000000000000000000000000000;
11 : 00000000000000000000000000000000;
10 : 00000000000000000000000000000000;
END;
