12 years agoHow to Import whole the truth table into Quartus and automatically Optimize it
Hi every one
I had designed a Combinational circuit in Quartus II 13.0 but it was not optimized as the number of input variables were so many I couldn't simplify it using Karnaugh Maps ,so I decided to draw whole truth table on the schematic environment with out pre-simplification, as I searched on the net I found out that Quartus does the simplification by it self after compilation. so after the compile I checked Netlist Viewers/technology map viewer(post filtering),I found the optimized circuit there ,I wonder if I can export or copy it from there and use it in schematic environment, on the other hand is there a way to import whole the truth table to the Quartus so that it automatically optimizes and makes logics by it self ? I'd be glad for any sort of hint. thank you
