13 years agoHow to identify if your design has a race condition.
I am currently working on a CPU and I managed to make it run an sequence of instructions (All it does is add 1 to a register and then store it into a memory mapped device which controls LEDs on my FPGA board and repeat) properly in modelsim however when I put it into a qsys system I have issues. I connect the CPU to an Onchip RAM component (through QSYS) which is preloaded with the same instructions.
When I loaded the design onto the FPGA I noticed that the LEDs increment for a VERY short time (Several microseconds or so) and then freeze. If I reset the System it will do the same thing but it will freeze at a different time. I tried using a ROM megafunction instead and I placed it inside of the CPU and it works perfectly fine. This led me to believe that there is an issue with the communication between the CPU and the Memory unit more specifically a race condition Is there any way to check if there is a race condition going on? EDIT: In some compilations the LEDs will always be in the reset state which makes me believe that it is a race condition and the duration can be affected from the fitting stage.
