13 years agoHmmm, I guess then I will have to change the instruction fetching unit to acommendate for it. I am going to test it first to see if the memory works when it is clocked 4 times higher then the CPU just to see if that is the issue. Also is there any way to tightly couple the memory with the CPU in QSYS or do I need to do it in the CPU design with a megafunction.
