9 years agogate lev sim not working as expected
hello everybody
im quite new in developing for FPGA. I have started wih DE0-nano board. im learning just programming an easy FSM that performs elementary operations. i have followed the tutorial for simulating the circuit with Modelsim-Altera. no problem with the flow of functional simulation. the operations are simulated in the sequence as expected. While trying to create timing simulation with the same Modelsim (gate level simulation) my FSM does not work as expected. The state of FSM is update in not controlled way. I have made several tries and i have the suspect to have wrong code the two process statement that concurrency run. The source code is in VHDL. So same code in VHD work in functional simulation and worngly work in gate level simulation. i would like to fix this issue to learn more about FPGA. Thank you21 Replies
I Notice the next_state and finito signal is not assigned in all branches, so it will create latches. This might be what is causing the problems.
--- Quote Start --- I Notice the next_state and finito signal is not assigned in all branches, so it will create latches. This might be what is causing the problems. --- Quote End --- what do you mean for .. is not assigned in all branches? - Altera_Forum
In an asynchronous process, all signals must be assigned in all cases, otherwise latchea will be created.
For example, when current state is 01, next state is only assigned when the counter gets to 7, otherwise it holds its state. This creates a latch. You must at least assign it to current state to avoid the latch. The same for finito. It is only assigned here. This creates a latch. - Altera_Forum
im going literally crazy ..
i have modified the code in this way
i got these waveforms ... https://www.alteraforum.com/forum/attachment.php?attachmentid=13083LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; USE ieee.numeric_std.all; ENTITY somma_FSM IS GENERIC ( WAIT_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"00"; WORK_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"01"; END_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"11" ); PORT ( ingressoA : IN STD_LOGIC; ingressoB : IN STD_LOGIC; inizia : IN STD_LOGIC; resetn :IN STD_LOGIC; clock : IN STD_LOGIC; finito : OUT STD_LOGIC; somma : OUT STD_LOGIC; resto : OUT STD_LOGIC ); END somma_FSM; ARCHITECTURE somma_FSM_architecture OF somma_FSM IS SIGNAL current_state :STD_LOGIC_VECTOR(1 DOWNTO 0); SIGNAL next_state :STD_LOGIC_VECTOR(1 DOWNTO 0); SIGNAL counter :STD_LOGIC_VECTOR(2 DOWNTO 0); SIGNAL resto_in :STD_LOGIC := '0'; SIGNAL resto_out :STD_LOGIC := '0'; BEGIN PROCESS(inizia, current_state, counter) BEGIN CASE(current_state) IS WHEN B"00" => IF (inizia = '1') THEN next_state <= B"01"; finito <= '0'; ELSE next_state <= B"00"; finito <= '0'; END IF; WHEN B"01" => IF (counter = B"111") THEN next_state <= B"11"; finito <= '1'; ELSE next_state <= B"01"; finito <= '0'; END IF; WHEN B"11" => next_state <= B"00"; finito <= '0'; WHEN OTHERS => END CASE; END PROCESS; PROCESS(resetn,clock) BEGIN IF (resetn = '0') THEN current_state <= WAIT_STATE; counter <= (OTHERS => '0'); ELSE IF ((clock'EVENT) AND (clock = '0')) THEN current_state <= next_state; IF (current_state = B"00") THEN counter <= (OTHERS => '0'); ELSE IF (current_state = B"01") THEN counter <= counter + '1'; resto_in <= resto_out; END IF; END IF; END IF; END IF; END PROCESS; somma <= ingressoA XOR ingressoB XOR resto_in; resto_out <= (ingressoA AND ingressoB) OR (ingressoA AND resto_in) OR (ingressoB AND resto_in); resto <= resto_out; --finito <= '1' WHEN current_state =B"11"; END somma_FSM_architecture; - Altera_Forum
Please post your test bench code, without it we cannot test your code.
--- Quote Start --- That is not a testbench - that ios the waveform output from the design. What code are you using to test your design? --- Quote End --- Sorry for the ignorance, For test bench code you mean eda netlist file in verilog generated for modelsim? - Altera_Forum
--- Quote Start --- Sorry for the ignorance, For test bench code you mean eda netlist file in verilog generated for modelsim? --- Quote End --- No - the testbench is the code you use to test your code - you have to generate inputs for the design somehow... - Altera_Forum
--- Quote Start --- No - the testbench is the code you use to test your code - you have to generate inputs for the design somehow... --- Quote End --- Sorry, i do not use test bench. I perform compilation in quartus, open modelsim, run the simulation and using modelsim Waveforms editors to provide input to dut. In wave window i add output waveforms to see what happens - Altera_Forum
--- Quote Start --- i got these waveforms ... https://www.alteraforum.com/forum/attachment.php?attachmentid=13083 --- Quote End --- This picture is too small and low quality we cannot see the actual waveforms. And without the test it is impossible to tell whats going on. But the appearance of U or X usually means that something is driving them that way. You should be able to add any signal to the wave window to trace back the drivers to see what is causing the problem. There isnt anything obviously wrong in your code., other than not assigning next_state and finito in the "others" case to cover their state when current state is "10" or "UU" or "XX". It could be something to do with this. Otherwise I can only assume a test bench issue.
