SayaliMore's avatar
SayaliMore
6 years ago
Flashing the CPLD using USB Blaster throws error(209015)
Initially I flashed the CPLD - MAX V 5M1270Z using USB Blaster and Quartus prime it was successful
Then, I was trying to reprogram CPLD using JTAG - JAM STAPL interface, where it gave me error code-11 "Device Verify Failure" so I tried to reflash the CPLD using USB Blaster in quartus prime software it showed me the below error.
Error (209015): Can't configure device. Expected JTAG ID code 0x020A30DD for device 1, but found JTAG ID code 0xFFFFFFFF. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Can anyone help me understand whether I am getting this error as flashing using JTAG has corrupted some JTAG ID code?? and how to now flash the software to CPLD as I am stuck
P.S: Setup was not disturbed, hence it is unlikely the issue with USB cables, TIA!!
  • JohnT_Altera's avatar
    JohnT_Altera
    Have you tried power cycle the board and reconnect the blaster to see if the issue is still observed?
    • SayaliMore's avatar
      SayaliMore
      Yes, I tried with the power cycle and even reconnecting the blaster multiple times,
      Sometimes the error code 35 was observed but then after restarting the PC again shows the same error code (209015)
  • ShubhamK's avatar
    ShubhamK
    Is IDCODE value is changeable ? I think its Read-Only & Can not be configured, am I correct ?
    JohnT_Altera
    The IDCODE is not changeable but from the issue that you observed, the TDO is stuck at 1. which cause the readout to be 0xFFFFFFFF
      SayaliMore
      I probed the TDO pin on DSO to check whether it is stuck at some logic level.
      But that was not the case I was able to see the signal getting toggled, when there is programming command from Quartus-Prime through Blaster
    JohnT_Altera
    May I know if you are not able to detect the device anymore after power cycling? If you no longer able to recover it then the device might be damaged.
    • ShubhamK's avatar
      ShubhamK
      We are not able to establish communication after power cycle. How can we make sure if device is damage ? Please help us with any steps, process to verify it.
    • ShubhamK's avatar
      ShubhamK
      VCCIO voltage is 3.3V & VCCINT voltage is 1.8V
      These are regulated voltages and generated from power rails.
      • ShubhamK's avatar
        ShubhamK
        Is there any way to make sure if device is damaged ? Like device could draw more current draw, something like that
    JohnT_Altera
    I suspect that the device might be damaged. I would recommend you to replace the device.
    JohnT_Altera
    No. There is no other method as you are no longer able to access the device using JTAG Chain
