SayaliMore
6 years agoFlashing the CPLD using USB Blaster throws error(209015)
Initially I flashed the CPLD - MAX V 5M1270Z using USB Blaster and Quartus prime it was successful
Then, I was trying to reprogram CPLD using JTAG - JAM STAPL interface, where it gave me error code...
JohnT_Altera
6 years agoHi,
The IDCODE is not changeable but from the issue that you observed, the TDO is stuck at 1. which cause the readout to be 0xFFFFFFFF
SayaliMore
6 years agoI probed the TDO pin on DSO to check whether it is stuck at some logic level.
But that was not the case I was able to see the signal getting toggled, when there is programming command from Quartus-Prime through Blaster
