From the following thread:
http://www.alteraforum.com/forum/showthread.php?t=5244&referrerid=2226 2 - What I do for production ... . a - Install the Quartus II standalone programmer on the production PC. Availalble here: https://www.altera.com/support/software/download/programming/quartus2/dnl-quartus2_programmer.jsp . b - Copy the following files from your development PC and package them with your programming files... . nios2-flash-programmer.exe . cygwin1.dll . jtag_atlantic.dll This should be all you need to run the nios2 flash programmer on the production PC. It's a whole lot faster than using the jtag indirect method with the quartus II programmer. - Altera_Forum
Hi, jakobjones, could you please tell me which directory on the production PC should I put the package copied from the development PC? One more question, is it necessary to put these files in the same fold or compress them? Thanks very much!
The Quartus II programmer just needs to be installed on the manufacturing PC. The files that I've indicated need to be copied need only be placed somewhere that you can access them. I put them in the same folder as my scripts or applications that perform the programming. No need to compress them and I wouldn't do so.
Jake - Altera_Forum
Thanks, Jake. However, when I use the nios2-flash-programmer command, it shows that "jtag_client.dll" does not exist. It seems that "jtag_client.dll" is also needed to be included in the same fold.
I believe that DLL exists in the Quartus II Programmer install. See if you can find it. You may need to add the path to the programmer as part of your path environment variable.
Jake - Altera_Forum
For example, my scripts add "C:\altera\80\qprogrammer\bin" to the PATH environment variable before running the programmer.
Jake - Altera_Forum
I right click "my computer" and choose "advanced" tag. Then by clicking "environment variables", I add a variable with the value of the directory where quartus II programmer is installed. However, I still cannot run the programmer. Is there something wrong? Thank you!
--- Quote Start --- From the following thread: http://www.alteraforum.com/forum/showthread.php?t=5244&referrerid=2226 2 - What I do for production ... . a - Install the Quartus II standalone programmer on the production PC. Availalble here: https://www.altera.com/support/software/download/programming/quartus2/dnl-quartus2_programmer.jsp . b - Copy the following files from your development PC and package them with your programming files... . nios2-flash-programmer.exe . cygwin1.dll . jtag_atlantic.dll This should be all you need to run the nios2 flash programmer on the production PC. It's a whole lot faster than using the jtag indirect method with the quartus II programmer. --- Quote End --- I'm wondering, are any licensing issues that I should be concerned about if I were to send these files to someone who does not originally have the NIOS EDK? - Altera_Forum
The NIOS EDK is freely available. Also, I have a hard time thinking that Altera would have any problem with someone using their tools to help produce products using their parts.
Jake
