16 years agoI believe that DLL exists in the Quartus II Programmer install. See if you can find it. You may need to add the path to the programmer as part of your path environment variable.
JakeI believe that DLL exists in the Quartus II Programmer install. See if you can find it. You may need to add the path to the programmer as part of your path environment variable.
Jake
