Error when running Power Analyzer with .vcd file in Quartus Prime Pro 24.2
- 1 year ago
Hi Noah,
We have root caused the issue. A fix for this issue will be scheduled on the upcoming version.
As a workaround for this, please remove the following line from the QSF file and rerun the full flow:
set_instance_assignment -name PARTITION component_and_func -to "and_func:and_func_inst"
May I know if you are willing to share the design file with me so that I can try to replicate this Internal Error?
These are the design files, including the .vcd generated during the simulation, and a .vcd converted from a .wlf file.
This project is generated from HLS Compiler, which could be relevant. The issue appeared in the context of a larger project but I tested this logical "and" functionality to have as simple a test as possible.
The Quartus project is inside \luinv.prj\quartus
When generating the same project for a Cyclone V board in Quartus Lite, Power Analysis does work, which is why I think the problem might not be related to HLS Compiler.
Let me know if you have any updates or need more information.
Noah
