Error when compiling dpc++ for fpga
- 2 years ago
Hi @KatariTF,
Noted with thanks on the repository, however the mention example design are from the open community. With limited ownership and access, hence we could only provide best effort support on the mention design.
Looking at the repo details it mentioning the hardware support are just limited to Stratix or Arria. Hence entering Agilex devices may cause an error. Hence would suggest perhaps to try compiled with the mention support devices. More details on the devices compilation flags can be found in the following link below:
Hope that clarify.
Best Wishes
BB
Hi @KatariTF,
Thank you for posting in Intel community forum and hope all is well.
Noted on the error, would you be able to share the URL of the example design you are trying to build with?
Also is it correct to assume that you are trying to build in the Intel DevCloud platform based on the screenshot?
Hope to hear from you soon.
Best Wishes
BB
- KatariTF2 years ago
Hello @BoonBengT_Altera ,
I'm trying to use fpga with Intel devCloud but, I didn't succeed. I also tried with vector_add but I had same error.
Second cuestion: Yes, i do.
