Error: loop with non-constant loop condition must terminate within 250 iterations
I am writing a test bench for a module and now I am getting this error, even though I have written a couple other test benches before it was all working fine but now I got this error, please help me solve this
//Testbench
You may try the following solution:
Description
This error may appear in the Quartus® II software when synthesis iterates through a loop in Verilog HDL for more than the synthesis loop limit. This limit prevents synthesis from potentially running into an infinite loop. By default, this loop limit is set to 250 iterations.
Resolution
To work around this error, the loop limit can be set using the VERILOG_NON_CONSTANT_LOOP_LIMIT option in the Quartus II Settings File (.qsf). For example:
set_global_assignment -name VERILOG_NON_CONSTANT_LOOP_LIMIT 300
- TingJiangT_Intel
Contributor
Description
Resolution
- bitte929
Thank you
- FvM
Do you expect that the "solution" will allow Quartus to synthesize the test bench code that causes the loop error?
forever#`HALF_CLOCK tb_clk = ~tb_clk;end - sstrell
Does the error point to a line number? What tool does this happen in?
There are no loops here with fixed iteration unless it's something in the PulseCounter.
- FvM
I see that the error is generated when you are compiling the testbench code in Quartus. This makes no sense, testbench must be compiled in simulator, e.g. Modelsim Altera Starter Edition shipped with Quartus 18.
- bitte929
yes I know but still it is throwing this error
- TingJiangT_Intel
Contributor
What's the detail error message, BTW Have you add the tb file to the project?
It may cause some problem when you compile tb with quartus.
- bitte929
Yes I have added the tb file, I get the error once in a while and after some time its gone without me doing anything, no clue and the detailed error is already pasted above and nothing more to that
- FvM
Presume you are still nonsensically trying to compile the project with testbench in Quartus?
- bitte929
yes
I have a question, in one project I can still have multiple module files and multiple test benches right, provided I configure them properly on which one I want to execute.
- WZ2
Hi there,
This may be the related solution. You may try this solution, and let's check if it can be addressed.
- bitte929
It worked thanks
- TingJiangT_Intel
Contributor
