Error: loop with non-constant loop condition must terminate within 250 iterations
- 2 years ago
You may try the following solution:
Description
This error may appear in the Quartus® II software when synthesis iterates through a loop in Verilog HDL for more than the synthesis loop limit. This limit prevents synthesis from potentially running into an infinite loop. By default, this loop limit is set to 250 iterations.
Resolution
To work around this error, the loop limit can be set using the VERILOG_NON_CONSTANT_LOOP_LIMIT option in the Quartus II Settings File (.qsf). For example:
set_global_assignment -name VERILOG_NON_CONSTANT_LOOP_LIMIT 300
Does the error point to a line number? What tool does this happen in?
There are no loops here with fixed iteration unless it's something in the PulseCounter.
- bitte9292 years ago
Points to line 18 i.e. (#`HALF_CLOCK tb_clk = ~tb_clk;)
Tool: Intel quartus prime 18.1 when I am writing a test bench- sstrell2 years ago
Yeah, you can't compile a testbench like this in Quartus. It has to be in your simulation tool.
Yes I have already compiled some test benches on Model Sim Altera and it was working fine on the same PC but now all of a sudden this error popped up
