18 years agoDSP Builder and Signal Tap II
I have some simple questions. I working on an Altera DE2 with a Cyclon II FPGA inside. I'm doing some simulation with the DSP Builder like simulate a stair signal ora a Sinewave signal and catching it with the Signal tap. I'm in trouble with the clock I think. 1)To set the real clock of the board I have to use the clock block obviously...but..anithing else? Should I have to make a PIN assignement? (with the pinout assignement block?) 2) If the signal is too slow maybe the max 8k of samples of the Signal Tap are not enough to see something concrete, so I 've decided to use a derived clock to clock the signal tap slower. Everything is good till I start the data acquisition: the acquisition doesn't stop and I have to turn off the board Any help? Any idea? THANK YOU
