17 years agoThe discussion has been regarding requirements for a suitable acquisition clock. It's not said, that you can't use a gated clock at all. It may work, although the timing is probably not perfect. I often use it as a quick and dirty solution. Alternatively you can use segemented trigger to acquire data at a reduced rate. If I understand right, Quartus 8 has new options in this regard, but I didn't evaluate them yet.
