18 years agoHi,
(1) You will have to make PIN assignments. However, the best way is to include the Cyclone II DE2 board block (can be found under board blocks in version 7.2). If you double click on that block, you will realize that all pin assignments were made for you already. That would probably save you a lot of trouble. (2) I believe your problem is due to the lack of pin assignments. I haven't had a problem seeing signals with SignalTap (however fast or slow). Hope this helps!
