18 years agoI've just put my DE2 board block in the schematics, so are there no other assignements to do more then the ones in the board block? Also if I use the clock block? And also if I use the clock derived block?
I think to have solved the problem anyway. I think that the problem was in using a derived clock for the signal tap so I 've used the base clock for the SIgnal Tap and I've speeded up the simulation with a PLL clock. The manual is not really clear about PIN assignement and clocks...
