13 years agoData+clk path through (constraints)
Im trying to specify timing constraints for a simple design but i dont know how to fully complete the constraints. I still have unconstrained paths: 'clk_in' and 'clk_out' report_ucp -panel_name "Unconstrained Paths" Design is not fully constrained for setup requirements Design is not fully constrained for hold requirements The datapath is registered but not the clock path. The datapath seems to be fully constrained but the is still problem with the clock path. (no setup/hold for the "clk_out <= clk <= clk_in" path) Can anybody help me? Solution/explaination. Thanks. Bkirks :) ...see vhdl + sdc here: <<data_clk_pass_through .vhd .... >> entity data_clk_pass_through is port ( Din : in unsigned (24 downto 0); Dout : out unsigned (24 downto 0); clk_in : in std_logic; clk_out : out std_logic ); end entity; architecture rtl of data_clk_pass_through is signal clk : std_logic; begin process (clk) begin if (rising_edge(clk)) then Dout <= Din; end if; end process; clk <= clk_in; clk_out<=clk; end rtl; <<data_clk_pass_through .vhd................. end>> <<timing.sdc ..........>> #************************************************************** # Time Information #************************************************************** set_time_format -unit ns -decimal_places 3 #Specify the clock period set dvi_period 8.000 #********************************************* #DVI_RX_device (TFP 401) #Specify the required tSU + tH set dvi_rx_tSU 2.100 set dvi_rx_tH 0.500 #Boarddelay set dvi_rx_BD_dmin 0.000 set dvi_rx_BD_dmax 0.000 set dvi_rx_BD_cmin 0.000 set dvi_rx_BD_cmax 0.000 #********************************************* #********************************************* #DVI_TX_device (TFP 410) #Specify the required tSU + tH set dvi_tx_tSU 1.200 set dvi_tx_tH 1.300 #Boarddelay set dvi_tx_BD_dmin 0.000 set dvi_tx_BD_dmax 0.000 set dvi_tx_BD_cmin 0.000 set dvi_tx_BD_cmax 0.000 #********************************************** #************************************************************** # Create Clock #************************************************************** create_clock -name clk_in -period $dvi_period [get_ports {clk_in}] create_clock -name clk_virtual -period $dvi_period create_clock -name clk_out -period $dvi_period [get_ports {clk_out}] #************************************************************** # Set Input Delay #************************************************************** set_input_delay -clock [get_clocks {clk_virtual}] -max [expr $dvi_period - ($dvi_rx_tSU + ($dvi_rx_BD_cmin - $dvi_rx_BD_dmax))] [get_ports {Din*}] set_input_delay -clock [get_clocks {clk_virtual}] -min [expr $dvi_rx_tH - ($dvi_rx_BD_cmax - $dvi_rx_BD_dmin)] [get_ports {Din*}] #************************************************************** # Set Output Delay #************************************************************** set_output_delay -clock [get_clocks { clk_out }] -max [expr ($dvi_tx_tSU -($dvi_tx_BD_dmax-$dvi_tx_BD_cmin)) ] [get_ports {Dout*}] set_output_delay -clock [get_clocks { clk_out }] -min [expr -($dvi_tx_tH -($dvi_tx_BD_cmax-$dvi_tx_BD_dmin)) ] [get_ports {Dout*}] <<timing.sdc ..........end>>
