13 years agoHi B_Kirk, in the sdc file under clocks definitions add "derive_clock_uncertainty" command. This will calculate uncertainty between all clocks in design. Maybe this will help.
edit: you can drive your process and clk_out port directly by clk_in: --- Quote Start --- process (clk_in) begin if (rising_edge(clk_in)) then Dout <= Din; end if; end process; clk_out<=clk_in; --- Quote End ---
