Cyclone V & GTS PMA
How do you connect the Cyclone V to the GTS PMA transceiver ?
Regarding your inquiry on the example design, for your information, you can generate Direct PHY example design from the Direct PHY IP. You may refer to the "GTS PMA/FEC Direct PHY Intel FPGA IP Example Design" section in the GTS Transceiver PHY User Guide: Agilex 5 FPGAs and SoCs for further details.
Please feel free to let me know if you have any concern. Thank you.
- SDavi9
Does such a design exit ? Has anyone had any experience with this ?
- CheepinC_altera
Thank you for filing this case and sharing the details. I appreciate your patience. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
- CheepinC_altera
Just to keep you posted on the progress. I have been checking through the device datasheets on the TX and RX specs. I am currently clarifying some info with Factory and will keep you posted once received any valid data from them. Thank you.
- SDavi9
Dear CheePin,
Thank you for all your help. For the time being I found the following Intel Manuals : GTS Transceiver PHY User Guide Agilex™ 5 FPGAs and SoCs AND the GTS Ethernet Intel® FPGA Hard IP User Guide Agilex™ 5 FPGAs and SoCs and have tried to follow the guidelines there to create a system that can be tested on the Agilex 5 Premium development board. It would be VERY helpful if there was some sort of design example to follow to create the system and to double check what I have done !
KT
Shmuel
- CheepinC_altera
- CheepinC_altera
Just to keep you informed—based on a review of the datasheets for both the Cyclone V (CV) and Agilex 5 GTS transceivers, there should be no fundamental issues interfacing between the two devices. For your reference, please consult the following sections during your cross-verification:
Cyclone V Datasheet:
Transmitter Specifications for GX, GT, SX, and ST Devices
Receiver Specifications for GX, GT, SX, and ST DevicesAgilex 5 Datasheet:
Transmitter Electrical Specifications
Receiver Electrical SpecificationsIt’s generally recommended to use AC coupling to mitigate common-mode voltage mismatches between the devices. Additionally, I suggest performing signal integrity simulations to validate the link performance under your specific operating conditions.
Let me know if you have any concerns or need further assistance. Thank you.
- CheepinC_altera
I believe that your initial question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you very much.
