Cyclone V & GTS PMA
- 1 year ago
Regarding your inquiry on the example design, for your information, you can generate Direct PHY example design from the Direct PHY IP. You may refer to the "GTS PMA/FEC Direct PHY Intel FPGA IP Example Design" section in the GTS Transceiver PHY User Guide: Agilex 5 FPGAs and SoCs for further details.
Please feel free to let me know if you have any concern. Thank you.
Dear CheePin,
Thank you for all your help. For the time being I found the following Intel Manuals : GTS Transceiver PHY User Guide Agilex™ 5 FPGAs and SoCs AND the GTS Ethernet Intel® FPGA Hard IP User Guide Agilex™ 5 FPGAs and SoCs and have tried to follow the guidelines there to create a system that can be tested on the Agilex 5 Premium development board. It would be VERY helpful if there was some sort of design example to follow to create the system and to double check what I have done !
KT
Shmuel
