amildm
Contributor
3 years agoCyclone 10 PLLs -> downscale clocks -> how much possible?
Hi All,
I'm working with Cyclone 10 GX, which has a reference clock of 100MHz .
What lowest frequency could I reach with PLLs using this clock as a reference clock?
I've tried to play with Fractional and Integer PLLs and the lowest frequency I succeeded to reach was 3MHz. Is it possible to reach lower frequencies?
How can I set cascading of the PLLs?
Thank you!
- Hello,
minimal output frequency is definer bei VCO frequency range and output divider factor. It's about 0.6 MHz. Lower frequencies can be achieved with frequency divider in core logic.
- FvM
minimal output frequency is definer bei VCO frequency range and output divider factor. It's about 0.6 MHz. Lower frequencies can be achieved with frequency divider in core logic. - NazrulNaim_Intel
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
- NazrulNaim_Intel
As per the answer provided by user named 'FvM'. The answer can be accepted. Lower frequencies can be achieved with frequency divider in core logic.
Nazrul Naim
