18 years agocritical path:70% IC delay + 30% CELL delay
I hope my system can run at 100MHz.
After full compilation, the timing report show me that fmax<80MHz. And I found that the critical path contain 70% IC delay + 30% CELL delay,pls see below:
Info: Slack time is -11.725 ns for clock "clk" between source register "FreqMeasure_NiosII:inst|jtag_debug_module_pipeline_bridge:the_jtag_debug_module_pipeline_bridge|jtag_debug_module_pipeline_bridge_downstream_adapter:the_jtag_debug_module_pipeline_bridge_downstream_adapter|m1_address" and destination register "FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|avs_freqmeasure_slave_readdata"
Info: Fmax is 54.37 MHz (period= 18.391 ns)
Info: + Largest register to register requirement is 6.347 ns
Info: + Setup relationship between source and destination is 6.666 ns
Info: + Latch edge is 6.666 ns
Info: Clock period of Destination clock "clk" is 6.666 ns with offset of 0.000 ns and duty cycle of 50
Info: Multicycle Setup factor for Destination register is 1
Info: - Launch edge is 0.000 ns
Info: Clock period of Source clock "clk" is 6.666 ns with offset of 0.000 ns and duty cycle of 50
Info: Multicycle Setup factor for Source register is 1
Info: + Largest clock skew is -0.055 ns
Info: + Shortest clock path from clock "clk" to destination register is 3.256 ns
Info: 1: + IC(0.000 ns) + CELL(1.100 ns) = 1.100 ns; Loc. = PIN_T2; Fanout = 2; CLK Node = 'clk'
Info: 2: + IC(0.135 ns) + CELL(0.000 ns) = 1.235 ns; Loc. = CLKCTRL_G3; Fanout = 23640; COMB Node = 'clk~clkctrl'
Info: 3: + IC(1.355 ns) + CELL(0.666 ns) = 3.256 ns; Loc. = LCFF_X54_Y13_N23; Fanout = 1; REG Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|avs_freqmeasure_slave_readdata'
Info: Total cell delay = 1.766 ns ( 54.24 % )
Info: Total interconnect delay = 1.490 ns ( 45.76 % )
Info: - Longest clock path from clock "clk" to source register is 3.311 ns
Info: 3: + IC(1.410 ns) + CELL(0.666 ns) = 3.311 ns; Loc. = LCFF_X52_Y32_N9; Fanout = 1431; REG Node = 'FreqMeasure_NiosII:inst|jtag_debug_module_pipeline_bridge:the_jtag_debug_module_pipeline_bridge|jtag_debug_module_pipeline_bridge_downstream_adapter:the_jtag_debug_module_pipeline_bridge_downstream_adapter|m1_address'
Info: Total cell delay = 1.766 ns ( 53.34 % )
Info: Total interconnect delay = 1.545 ns ( 46.66 % )
Info: - Micro clock to output delay of source is 0.304 ns
Info: - Micro setup delay of destination is -0.040 ns
Info: - Longest register to register delay is 18.072 ns
Info: 1: + IC(0.000 ns) + CELL(0.000 ns) = 0.000 ns; Loc. = LCFF_X52_Y32_N9; Fanout = 1431; REG Node = 'FreqMeasure_NiosII:inst|jtag_debug_module_pipeline_bridge:the_jtag_debug_module_pipeline_bridge|jtag_debug_module_pipeline_bridge_downstream_adapter:the_jtag_debug_module_pipeline_bridge_downstream_adapter|m1_address'
Info: 2: + IC(3.079 ns) + CELL(0.589 ns) = 3.668 ns; Loc. = LCCOMB_X63_Y45_N2; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2194'
Info: 3: + IC(3.565 ns) + CELL(0.206 ns) = 7.439 ns; Loc. = LCCOMB_X21_Y42_N0; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2195'
Info: 4: + IC(0.360 ns) + CELL(0.206 ns) = 8.005 ns; Loc. = LCCOMB_X21_Y42_N14; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2196'
Info: 5: + IC(0.364 ns) + CELL(0.366 ns) = 8.735 ns; Loc. = LCCOMB_X21_Y42_N26; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2199'
Info: 6: + IC(1.872 ns) + CELL(0.370 ns) = 10.977 ns; Loc. = LCCOMB_X15_Y46_N8; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2200'
Info: 7: + IC(0.377 ns) + CELL(0.370 ns) = 11.724 ns; Loc. = LCCOMB_X15_Y46_N18; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2211'
Info: 8: + IC(3.381 ns) + CELL(0.370 ns) = 15.475 ns; Loc. = LCCOMB_X33_Y19_N16; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|Mux45~2339'
Info: 9: + IC(2.283 ns) + CELL(0.206 ns) = 17.964 ns; Loc. = LCCOMB_X54_Y13_N22; Fanout = 1; COMB Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|avs_freqmeasure_slave_readdata~10805'
Info: 10: + IC(0.000 ns) + CELL(0.108 ns) = 18.072 ns; Loc. = LCFF_X54_Y13_N23; Fanout = 1; REG Node = 'FreqMeasure_NiosII:inst|freqmeasure_avaloninterface_inst:the_freqmeasure_avaloninterface_inst|freqmeasure_wholesystem:the_freqmeasure_wholesystem|avs_freqmeasure_slave_readdata'
Info: Total cell delay = 2.791 ns ( 15.44 % )
Info: Total interconnect delay = 15.281 ns ( 84.56 % )
pls note: Info: Total cell delay = 2.791 ns ( 15.44 % ) Info: Total interconnect delay = 15.281 ns ( 84.56 % ) anybody guide me how to improve it? Thanks in advance!
