18 years agoHi David,
maybe I'm wrong, but according to your timing report you have used 150 MHz (6.66666ns) as clock constraint. Overconstraining a design leads often to worse timing results. If you would like to achieve only 100MHz , try to use 100MHz as clock setting. Kind regards Gerd
