9 years ago
Constrained clock appears as unconstrained input
I've spent a considerable amount of time several months ago to look into timing constraint issues, but had never understood how it works ... all this staff, despite several manuals I looked through.
Then I abandoned it in favour of other things.
Recently I returned to that work, and once more face these issues.
So here is my constraint file - it was generated by Terasic System Builder and then I added some additional instructions, in particular, create_clock and create_generated_clock.
Timing Analysis reports 2 violations: one unconstrained input port and on unconstrained output port.
CLOCK_50 No input delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment.
DRAM_CLK No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment.
But input port is part of create_clock instruction, so must be considered as constrained, and output port is part of create_generated_clock instruction, so also must be considered as constrained (if my comprehension is correct).
Where I've been mistaken ?
Thanks in advance.
#**************************************************************#  This .sdc file is created by Terasic Tool.#  Users are recommended to modify this file to match users logic.# **************************************************************
# **************************************************************#  Create Clock# **************************************************************
create_clock -period 20.0 -name clk CLOCK_50
create_clock -period 20.0 -name clk_dram# create_clock -period "100 MHz" -name clk_dram
#  for enhancing USB BlasterII to be reliable, 25MHz
create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
set_input_delay -clock altera_reserved_tck -clock_fall 3
set_output_delay -clock altera_reserved_tck 3
# **************************************************************#  Create Generated Clock# **************************************************************
create_generated_clock -name clk_sdram_ext -source  # derive_pll_clocks
# **************************************************************#  Set Clock Latency# *************************************************************
# **************************************************************#  Set Clock Uncertainty# **************************************************************
derive_clock_uncertainty
# **************************************************************#  Set Input Delay# **************************************************************#  Board Delay (Data) + Propagation Delay - Board Delay (Clock)
set_input_delay -max -clock clk_dram -0.048
set_input_delay -min -clock clk_dram -0.057
# **************************************************************#  Set Output Delay# **************************************************************#  max : Board Delay (Data) - Board Delay (Clock) + tsu (External Device)#  min : Board Delay (Data) - Board Delay (Clock) - th (External Device)
set_output_delay -max -clock clk_dram 1.452
set_output_delay -min -clock clk_dram -0.857
set_output_delay -max -clock clk_dram 1.531
set_output_delay -min -clock clk_dram -0.805
set_output_delay -max -clock clk_dram 1.533
set_output_delay -max -clock clk_dram 1.510
set_output_delay -min -clock clk_dram -0.800
set_output_delay -max -clock clk_dram 1.520
set_output_delay -min -clock clk_dram -0.780
set_output_delay -max -clock clk_dram 1.5000
set_output_delay -max -clock clk_dram 1.545
set_output_delay -min -clock clk_dram -0.755
set_output_delay -max -clock clk_dram 1.496
set_output_delay -min -clock clk_dram -0.804
set_output_delay -max -clock clk_dram 1.508
set_output_delay -min -clock clk_dram -0.792
# **************************************************************#  Set Clock Groups# **************************************************************
# **************************************************************#  Set False Path# **************************************************************
set_false_path -from
set_false_path -from * -to
    I'm totally desperate
    I still cannot resolve this issue with unconstrained path, related to output clock.
    According to different documents, I've examined until now, the a port, that is target in create_generated_clock constraint is considered as constrained.
    ... at least in multiple examples if output port serves as target in create_generated_clock constraint, there is no set_output_delay constraint for this port.
    Indeed, in other design that I've created some time ago and that is very similar to the actual one (I'm working on now), the identical output port isn't signaled as unconstrained.
    I'v reduced the dissimilarities of these two designs to a minimum ... I've even instantiated the qsys module from "good" design into the "bad" one.
    Does't help !!!
    The output port is still signaled as unconstrained.
    What should I check in my design to track down this mysterious issue.
    Thanks in advance.
    Output generated clock paths need to be set as false paths. The tool looks at output paths as data paths still, even though you've created a clock for it. Just false path the output clock.
    Thanks Sstrell,
    But I wonder why in another, quasi identical design, this annoying issue doesn't appear ?
    And in this design output clock isn't specified as false path.
    If a generated clock constraint targets an output pin, you will always see this. Perhaps there's some IP in this other design that handles it automatically for you.
    --- Quote Start ---
    --- Quote End ---
    The both designs are very simple: top level wrapping Verilog module, where is instantiated Qsys module (the same Qsys in both).
    Without seeing the constraints or the design, there's no way for me to know why they are different.
    --- Quote Start ---
    --- Quote End ---
    "Good" design constraints:
    create_clock -name clk -period 20 create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
    derive_pll_clocks
    create_generated_clock -name clk_ext_sdram -source .gpll~PLL_OUTPUT_COUNTER|divclk}]
    #  Constraint SDRAM DATA for input
    set_input_delay -clock clk_ext_sdram -max 6.4 ]
    set_input_delay -clock clk_ext_sdram -min 1.0 ]
    #  Constraint SDRAM DATA for output
    set_output_delay -clock clk_ext_sdram -max 1.5
    set_output_delay -clock clk_ext_sdram -min -0.8
    # set_multicycle_path -setup -to }] 2# set_multicycle_path -hold -to }] 1
    "Bad" design constraints:
    derive_pll_clocks
    create_generated_clock -name clk_sdram_ext -source .gpll~PLL_OUTPUT_COUNTER|divclk}]
    create_generated_clock -name clk_data -source .gpll~PLL_OUTPUT_COUNTER|divclk}] |clk}]
    set_input_delay -clock clk_sdram_ext -max -0.048
    set_input_delay -clock clk_sdram_ext -min -0.057
    set_output_delay -clock clk_sdram_ext -max 1.452
    set_output_delay -clock clk_sdram_ext -min -0.857
    set_output_delay -clock clk_sdram_ext -max 1.531
    set_output_delay -clock clk_sdram_ext -min -0.805
    set_output_delay -clock clk_sdram_ext -max 1.533
    set_output_delay -clock clk_sdram_ext -max 1.510
    set_output_delay -clock clk_sdram_ext -min -0.800
    set_output_delay -clock clk_sdram_ext -max 1.520
    set_output_delay -clock clk_sdram_ext -min -0.780
    set_output_delay -clock clk_sdram_ext -max 1.5000
    set_output_delay -clock clk_sdram_ext -max 1.545
    set_output_delay -clock clk_sdram_ext -min -0.755
    set_output_delay -clock clk_sdram_ext -max 1.496
    set_output_delay -clock clk_sdram_ext -min -0.804
    set_output_delay -clock clk_sdram_ext -max 1.508
    set_output_delay -clock clk_sdram_ext -min -0.792
    "Good" design top module
    module nios_led2_top (input clk,     input  sw,
        input  key,
        output  led_l, led_h,
        output  hex3, hex2 , hex1, hex0,
        output  sdram_addr,
        inout  sdram_dq,
        output  sdram_bank,
        output sdram_cas_n, sdram_ras_n, sdram_cke, sdram_cs_n, sdram_clk,
        output sdram_dqmh, sdram_dqml, sdram_we_n);
        wire  sseg;
        assign hex3 = sseg;
        assign hex2 = sseg;
        assign hex1 = sseg;
        assign hex0 = sseg;
       nios_led2_sdram u0 (
              .btn_export       (key),
              .clk_clk          (clk),
            .led_l_export     (led_l),
              .led_h_export     (led_h),
              .reset_reset_n    (1'b1),
              .sdram_wire_addr  (sdram_addr),
              .sdram_wire_ba    (sdram_bank),
              .sdram_wire_cas_n (sdram_cas_n),
              .sdram_wire_cke   (sdram_cke),
              .sdram_wire_cs_n  (sdram_cs_n),
              .sdram_wire_dq    (sdram_dq),
              .sdram_wire_dqm   ({sdram_dqmh, sdram_dqml}),
              .sdram_wire_ras_n (sdram_ras_n),
              .sdram_wire_we_n  (sdram_we_n),
              .sseg_export      (sseg),
              .switch_export    (sw),
              .clk_sdram_clk    (sdram_clk)
    endmodule
    "Bad" design top module:
    //  This code is generated by Terasic System Builder
    module ch_11(
        //////////// CLOCK //////////
        input                           CLOCK_50,
        //////////// SDRAM //////////
        output                    DRAM_ADDR,
        output                     DRAM_BA,
        output                          DRAM_CAS_N,
        output                          DRAM_CKE,
        output                          DRAM_CLK,
        output                          DRAM_CS_N,
        inout                     DRAM_DQ,
        output                          DRAM_LDQM,
        output                          DRAM_RAS_N,
        output                          DRAM_UDQM,
        output                          DRAM_WE_N,
        //////////// SEG7 //////////
        output                     HEX0,
        output                     HEX1,
        output                     HEX2,
        output                     HEX3,
        //////////// KEY //////////
        input                      KEY,
        //////////// LED //////////
        output                     LEDR,
        //////////// SW //////////
        input                      SW
    //  REG/WIRE declarations
    //  Structural coding
    //    ch_11_nios u0 (
    //        .clk_clk       (CLOCK_50),       //    clk.clk
    //        .reset_reset_n (1'b1), //  reset.reset_n
    //        .switch_export (SW), // switch.export
    //        .btn_export    (KEY),    //    btn.export
    //        .sseg_export   ({{1'b0,HEX3},{1'b0,HEX2},{1'b0,HEX1},{1'b0,HEX0}}),   //   sseg.export
    //        .sdram_addr    (DRAM_ADDR),    //  sdram.addr
    //        .sdram_ba      (DRAM_BA),      //       .ba
    //        .sdram_cas_n   (DRAM_CAS_N),   //       .cas_n
    //        .sdram_cke     (DRAM_CKE),     //       .cke
    //        .sdram_cs_n    (DRAM_CS_N),    //       .cs_n
    //        .sdram_dq      (DRAM_DQ),      //       .dq
    //        .sdram_dqm     ({DRAM_UDQM, DRAM_LDQM}),     //       .dqm
    //        .sdram_ras_n   (DRAM_RAS_N),   //       .ras_n
    //        .sdram_we_n    (DRAM_WE_N),    //       .we_n
    //        .led_export    (LEDR),     //    led.export
    //          .sdram_clk_clk (DRAM_CLK)         //      sdram_clk.clk
              .btn_export       (KEY),
            .led_l_export     (LEDR),
              .led_h_export     (LEDR),
              .sdram_wire_addr  (DRAM_ADDR),
              .sdram_wire_ba    (DRAM_BA),
              .sdram_wire_cas_n (DRAM_CAS_N),
              .sdram_wire_cke   (DRAM_CKE),
              .sdram_wire_cs_n  (DRAM_CS_N),
              .sdram_wire_dq    (DRAM_DQ),
              .sdram_wire_dqm   ({DRAM_UDQM, DRAM_LDQM}),
              .sdram_wire_ras_n (DRAM_RAS_N),
              .sdram_wire_we_n  (DRAM_WE_N),
              .clk_sdram_clk    (DRAM_CLK)
    endmodule
    Here is unconstrained output in "Bad" module:
    In the "good" constraints, you've created a set_output_delay targeted to sdram*. Thus, this output delay constraint is covering the data output timing of this output clock, which as I mentioned, should not be constrained because you want it analyzed as a clock path, not a data path. Thus, you don't get the unconstrained path.
    In the "bad" constraints, you're not doing this, so DRAM_CLK appears unconstrained because it's still considered a data path.
    --- Quote Start ---
    --- Quote End ---
    Indeed, it's the case. Thanks a lot !
