12 years ago
Connect between Blocks at VHDL
Hi ,
i'm starting my final BS.c project and i'm doing it at Quartos and VHDL .
I have blocks that i design at vhdl and i want to connect between them (logicly) ,
i know that there is an option to define each block as a component at different file and define each block at the top file of the project
and make instantiation at the top file .
Is this the right solution of doing it ?
Does instantiation means to connect between to components or connect between signal to I/O port and vice versa ?
    When you instantiate a component you can map its inputs and output to the inputs and output of the top level entity or to internal signals. To connect the signal of 2 components use internal signals. I post a code of a circuit based on nand gates. This gates were implemented in a different component and instantiated many times. It's only for academic purposes.
    appreciate your answer ,
    Few more questions :
    what do i write at the top level entity ? is it the entity declaration and Instantiation and interconnections ?
    where do i write the design of the entity ? at other file or at the same file ?
    Thank you very much !
    First you create a Quartus project with a name, say it "toto" for example. usually you give the same name to the top level entity:
    entity toto is....
    if you give a different, an error appears during compilation saying that can't find top level entity. Go to Assignments->Setting->general and select the top level entity from the box "Top-level entity".
    Below the entity declaration, in same fiel, u write the architecture ( what you called the design of the entity ). Here you place the instantiation of the component ( entities located in diffent files. All files must be added to the project ).
    I understand ,
    At the files that you sent me there weren't components , just entities ; then at the second file you wrote the architecture .
    can i work that way ? without components ? and then write the architecture of the entities at different files ?
    thanks bertulus .
    No. All files has an entity declaration and a architecture. The entity defines a circuit as a black box and architecture says what are inside the box.
    For example if you design a not gate:
    entity not_gate is
    port(
    ent : in std_logic;
    sal : out std_logic
    end entity not_gate;
    architecture some_name_of_arch of not_gate is
    -- signals declarations
    begin
    sal <= not ent;
    end architecture some....
    u use this structure in all vhdl files.
    Second. The code seems that i not use component. i used without explicitily saying. In the line:
    nand_1: entity work.nand_3 (implementacion)
    port map( i1 => b , i2 => c , i3 => d , o => g );
    I'm using entity nand3 as a component. In the old fashion vhdl you have to declare a component with the "component" reserved word, and then use it. It's a wordy way of use components. In modern vhdl you can use an entity as a component not declared previously.
    Thank you very much bertulus ,
    you made it look very easy with your explanation ,
    appreciate it so much ,
    odedidush .
    Actually, components are still needed when you do mixed code instantiation (say VHDL isntantiating AHDL or Verilog) or a black box. Using direct instantiation makes the compiler check the entity, which means missmatches are picked up soon. If you use a component, the missmatch wont appear until it tries to map the component to an entity at the elaboration stage, which could be 10 minutes later in a large compile.
