12 years agoNo. All files has an entity declaration and a architecture. The entity defines a circuit as a black box and architecture says what are inside the box.
For example if you design a not gate: entity not_gate is port( ent : in std_logic; sal : out std_logic ); end entity not_gate; architecture some_name_of_arch of not_gate is -- signals declarations begin sal <= not ent; end architecture some.... u use this structure in all vhdl files. Second. The code seems that i not use component. i used without explicitily saying. In the line: nand_1: entity work.nand_3 (implementacion) port map( i1 => b , i2 => c , i3 => d , o => g ); I'm using entity nand3 as a component. In the old fashion vhdl you have to declare a component with the "component" reserved word, and then use it. It's a wordy way of use components. In modern vhdl you can use an entity as a component not declared previously.
