12 years agoWhen you instantiate a component you can map its inputs and output to the inputs and output of the top level entity or to internal signals. To connect the signal of 2 components use internal signals. I post a code of a circuit based on nand gates. This gates were implemented in a different component and instantiated many times. It's only for academic purposes.
