10 years agoClock gating with enable or not
Here is a n00b question from one which is rusty in VHDL:
The statement is not to gate the clock, but is the following considered clock gating? ena is a synchronous enable signal.
process (clk)
begin
if clk'event and clk='1' then
if ena='1' then
-- useful code
end if;
end if;
end process;
Is this above functionally the same as the line below? Syntax-wise it seems so, but it starts to feel awfully like gating.
if clk'event and clk='1' and ena='1' then
You can use synthesis attribute direct_enable set to false but you can get lut instead of sload signal for LE
And replace checking for clock edge with rising_edge cause later provide real 0 to 1 compare it with X to 1 in your code Then using synchronous signal- you should allow it in synthesis. You can try utilize both sclear and sload so tool understand synchronous - Altera_Forum
--- Quote Start --- Here is a n00b question from one which is rusty in VHDL: The statement is not to gate the clock, but is the following considered clock gating? ena is a synchronous enable signal.
--- Quote End --- Compilers are good here and I assume they will not gate clock. But why divert away from simple template of first code to mislead the compilers?Is this above functionally the same as the line below? Syntax-wise it seems so, but it starts to feel awfully like gating. if clk'event and clk='1' and ena='1' then - Altera_Forum
Oh... I've tried to use template from quartus text editor. perhaps it shoud be verified. What can be in else clause for sync_load???
-- In Altera devices, register signals have a set priority. -- The HDL design should reflect this priority. process(<reset>, <aload>, <adata>, <clock_signal>) begin -- The asynchronous reset signal has the highest priority if (<reset> = '0') then <register_variable> <= '0'; -- Asynchronous load has next-highest priority elsif (<aload> = '1') then <register_variable> <= <adata>; else -- At a clock edge, if asynchronous signals have not taken priority, -- respond to the appropriate synchronous signal. -- Check for synchronous reset, then synchronous load. -- If none of these takes precedence, update the register output -- to be the register input. if (rising_edge(<clock_signal>)) then if (<clock_enable> = '1') then if (<synch_reset> = '0') then <register_variable> <= '0'; elsif (<synch_load> = '1') then <register_variable> <= <synch_data>; else <register_variable> <= <data>; end if; end if; end if; end if; end process; - Altera_Forum
All signals inside branch for clock transition are synchronus.
even if it enable clock signal per LAB. (okay this signal could come along with active clock-edge?) I think about synchronus and synchronus, and clock-gating at source or enable clock per flip-flop. does documentation juggle the termins so free? Hope no, cause for each case we have a nice figures for clarification. but it is terrible. It is due to optimization technique. - Altera_Forum
finally, i found who is responible for such situation. Among 80 global assignments we have Auto Clock Enable Replacement which("witch") is on by default.
So default assignments is very smart , smarter than required.
